New rider confused! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 05-07-2012, 01:25 PM Thread Starter
brianc442's Avatar
New rider confused!
Alright, so I bought my bike about a week ago and everything's been going fine. Changed the oil, the plugs, & the battery. Batt currently reads 12.62V. She was stating up fine until I decided to put her into gear to take her for my first ride. Not surprisingly, I stalled the bike before I got going and now I can't get her to turn over. I have a feeling this is user error and not electrical...the neutral light is on & it does click when I try the starter but all the lights go out immediately. They go back on when I hit the horn or toggle the switch or basically play around with anything electrical. Ideas? Thanks in advance!
brianc442 is offline
post #2 of 10 (permalink) Old 05-07-2012, 01:42 PM
Check all ground connections. Loose ground cables can cause the symptoms you describe.
Also, the battery could read a charged voltage, but still be a bad battery. How old is it? You can take it to AutoZone to get load tested.
post #3 of 10 (permalink) Old 05-07-2012, 01:45 PM Thread Starter
brianc442's Avatar
Brand new battery, bought it last week. I'll check the grounds. Thanks
post #4 of 10 (permalink) Old 05-07-2012, 03:37 PM
Run switch in "off" position? been there, got the T-shirt.
03 VN750
nautillus horn
crash bars
saddlemen saddlebags
luggage rack
plexifairing 3 windshield
extended backrest
heated grips
led tail light
electro pods
dash board
Givi E-21 saddle bags
akrider is offline
post #5 of 10 (permalink) Old 05-07-2012, 04:19 PM
Kick stand switch sticking/faulty
Swagman is offline
post #6 of 10 (permalink) Old 05-07-2012, 04:41 PM Thread Starter
brianc442's Avatar
Rusty ground. Good call thtanner and thanks a lot.
post #7 of 10 (permalink) Old 05-07-2012, 04:45 PM
Senior Lurker
Sloppyburpfest's Avatar
FINE-C/C
Fuel = should be in the On or Run position
Ignition = should be in the On or Run position
Neutral = the bike should be in Neutral
Engine cut off Switch = should be in the On or Run position
Clutch = squeeze in the clutch
/ Choke = turn on the Choke if the engine is cold.
If doing all of that doesn't get the bike to start then yes, you have a maintenance issue.
-Sloppy
My Flickr Gallery < Link >
Küryakyn LED battery monitor
R.I.P. Lance328
Sloppyburpfest is offline
post #8 of 10 (permalink) Old 05-07-2012, 07:43 PM
Gemguy's Avatar
Hey Brian, are you in Nassau or Suffolk???
~VROC~ # 389
Gemguy is offline
post #9 of 10 (permalink) Old 05-09-2012, 06:21 AM Thread Starter
brianc442's Avatar
Nassau. Levittown, to be exact.
post #10 of 10 (permalink) Old 05-09-2012, 04:05 PM
Gemguy's Avatar
I ride with another VN750, a lot of trips to Oak Beach. If you are a new rider Oak Beach on a Sunday morning will blow your mind. Should I get in touch with you and let you know next time we go? I'm in East Rockaway and he's in Island Park. John is also on this forum but I can't remember his handle. Send me a PM if you're interested.
~VROC~ # 389
Gemguy is offline
