Continuity test nightmare - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 05-03-2012, 05:56 PM Thread Starter
Valkyrie Riding Member
F6Rider's Avatar
Ok...
Replaced stator, replaced r/r, replaced batt. Should be good, right? WRONG
Okay, since the damn thing doesn't seem to want to stay charged even after ALL THAT, I went ahead and started at the beginning with testing again.
Found that my Stator is grounding at 2 out of 3 points.
So, how do I figure out which points? And, how to I fix the issue?
...All you see from me are Dust & Taillights...
F6Rider is offline
post #2 of 6 (permalink) Old 05-03-2012, 07:27 PM
Was the stator new or used? If new I could contact the supplier!
post #3 of 6 (permalink) Old 05-03-2012, 07:49 PM
^what he said X2
post #4 of 6 (permalink) Old 05-03-2012, 09:21 PM Thread Starter
F6Rider's Avatar
Brand New ...
But I don't really want toeat remove the engine again to get this done. :-(
F6Rider is offline
post #5 of 6 (permalink) Old 05-04-2012, 03:28 PM
ifixf18s's Avatar
Where did you do your continutity checks from? The bullet connectors or at the R/R connector? If your doing it at the R/R connector try it at the bullet connectors and see if you get the same thing. Also, did you do a continuity check on it before you installed it?
Im assuming when you say grounded you mean from one of the wires to ground (chassis). If thats the case I think you have 2 problems with the stator.
There are two ways you need to check for continuity. Lets label the wires A,B,&C. Check Each wire to ground, all should read NO continuity to ground. Then A-B, A-C, & B-C all these readings should read 1-3 OHMS or close to it.
With that said if one leg were shorted to ground then All legs would be shorted to ground unless there is an open between two of the legs.
One of the guys here did a nice troubleshooting chart to follow, its been going around recently. You may be able to find it.
ifixf18s is offline
post #6 of 6 (permalink) Old 05-04-2012, 05:05 PM
here is the link for the troubleshooting flowchart:
http://www.scribd.com/doc/88523705/V...ide#fullscreen
