Lost spark ignition? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 04-28-2012, 09:22 AM Thread Starter
Hi,
Does our bikes use a "lost spark ignition"? Meaning, do the coils fire at the top of the exhaust stroke also? Almost all small engines do, and I've even had a chevy that did also.
4/12/12 1st bike ever! 95 VN 750 13k
New plug wires
Iridiums
Coil relay mod
MCCT mod
EPA stuff removed
Rear signals shaved
Shinko 170-110 oversized tourmaster tires
Splines lubed
Front signals relocated.
skyboxer is offline
post #2 of 3 (permalink) Old 04-28-2012, 12:08 PM
This was asked before, and I'm pretty sure the answer was NO. The plugs only fire at the end of the compression stroke.
post #3 of 3 (permalink) Old 04-28-2012, 12:13 PM
Originally Posted by skyboxer View Post
Hi,
Yes they do, as the ignition pickup coils receive a magnetic signal with every rotation of the alternator rotor which is attached to the end of the crankshaft.
I think the 3.8 liter V6 in my Olds is a lost spark ignition also.
It doesn`t have a distributor that rotates at half the speed of the crankshaft, but a 3 coil pack with spark plug leads for 2 cylinders attached to each coil.
Each coil fires both plugs on every 360* rotation of the crankshaft, so one spark must always be "lost" in the exhaust stoke of one or the other cylinder.
