ARRRGH!!! More light help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 23 (permalink) Old 04-19-2012, 07:34 PM Thread Starter
pittdave's Avatar
OK.. I bought the small Optronics light kit that most have pushed.. I added small corner braces off of the headlight allen mounts and they look great.. just think centered between the HL and turn signals and horns
My problem is in wiring.. i thought the acc leads in the HL bucket were 'hot' with ignition..which is what i want. I would rather have the extra lights always on.. BUT NO!!!! these wires are just on all the time.. so i need a switch
But is there any way to splice or plug these wires in so they will just be on with ignition??
HELP!!!!!
Pittsburgh Dave
2001 VN750...old ride
2003 VN1600.. new ride
pittdave is offline
post #2 of 23 (permalink) Old 04-19-2012, 07:47 PM
Patriot Guard Rider
The DEUCE's Avatar
HELP!!!!!
Yuuuuup. Install a 30amp relay with the spare wires and splice into the running lights to control the relay.
VN750 #9300 & VROC #33453
The DEUCE is offline
post #3 of 23 (permalink) Old 04-19-2012, 07:49 PM
Patriot Guard Rider
The DEUCE's Avatar
Heres a drawing that explains it perfectly:
post #4 of 23 (permalink) Old 04-19-2012, 08:44 PM Thread Starter
pittdave's Avatar
ok.. still lost but lemme see if i got this right
with pin 87 i use the power lead that came with the switch and go to the POS on the battery
pin 86.. does that go to the NEG on the batt or what do i connect it to??
30 is the positive wires from the lights.. i guess i have to Y-connect them together and then have one wire to the relay
85..heres where i'm stuck.. do i cut one of the parking light wires and splice in a new wire that then connects to this pin??
i assume that each cable trunking going to the turn signals has 4 wires?? pos and neg for parking lights and turn signal...right??
Pittsburgh Dave
pittdave is offline
post #5 of 23 (permalink) Old 04-19-2012, 09:33 PM
I think all your questions were answered in this thread:
https://www.vn750.com/forum/showthread.php?t=21283
That YOU started. Along with a pretty clear statement saying the accessory leads were "always hot"...and that you'd need a switch...
Not sure why you needed to start another thread on the same subject...
Feel free to make fun of me for pointing this out....
Knifemaker , resident post nazi.
post #6 of 23 (permalink) Old 04-19-2012, 09:54 PM
pin 87 to hot accessory lead wire.. its 10 amp fused already
pin 86 to accessory lead ground wire
the rest of it is just as TheDuce showed. its real simple... should take about 15 seconds to wire wire it all up...
post #7 of 23 (permalink) Old 04-19-2012, 09:56 PM Thread Starter
pittdave's Avatar
will this work
i drew this up.. will this work to have the lights on with ignition
Pittsburgh Dave
pittdave is offline
post #8 of 23 (permalink) Old 04-19-2012, 09:58 PM Thread Starter
pittdave's Avatar
listen.. i know im and idiot.. but ive got more wires than i know what to do with.. i want to do this without as much going back to the battery.. i already have my battery tender pigtail and some accent lights there already
Pittsburgh Dave
pittdave is offline
post #9 of 23 (permalink) Old 04-19-2012, 10:10 PM
romeobravo172
romeobravo172's Avatar
There should be 2 acessary hot wires Fused allready inside the headlamp case!
romeobravo172 is offline
post #10 of 23 (permalink) Old 04-19-2012, 10:17 PM Thread Starter
pittdave's Avatar
right.. there are 2 double-bullet connectors there.. one pos and one neg
Pittsburgh Dave
pittdave is offline
