tail lights - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 19 (permalink) Old 04-18-2012, 10:48 PM Thread Starter
tail lights
hey guys so i just found out my tail light is out but my brake light still works. anyone know the bulb size for a 1996 vulcan 750? and how do i go about replacing it?
LeonelRenteria is offline
post #2 of 19 (permalink) Old 04-18-2012, 11:09 PM
Probably uses a pair of standard dual element 1157 bulbs.
Just take the 4 screws out of the red tail/brake light lens to get to the bulbs.
(Usually need a #2 Phillips screwdriver.)
Push the bulb in and twist a few degrees counterclockwise, then pull out.
Notice that the locking pins on the side of the brass base are different distances from the bottom.
Orient the base of the new bulb to match the locking slots in the socket, push in and twist CW to lock.
Jiggle to ensure proper fit and test that both tail and brake light bulbs function before replacing lens.
post #3 of 19 (permalink) Old 04-20-2012, 12:13 AM Thread Starter
Awesome thanks for the advice!!!!
post #4 of 19 (permalink) Old 04-20-2012, 05:21 PM Thread Starter
ok i just replaced the bulbs but my tail light still wont come on any other suggestions?
post #5 of 19 (permalink) Old 04-20-2012, 05:48 PM
Check your connections under the seat. There is a white 3 pin socket: Black/yellow is ground
Blue is brake light
Red is running light and should be 12v with ignition on.
Blue wire should show 12V when you hit either brake (hand or foot switch activated)
Check your ground should have zero ohms to the frame.
post #6 of 19 (permalink) Old 04-20-2012, 05:59 PM
I knew you had a problem when you first posted this. There are two bulbs and the chance of both of them not working is very slim. Be sure to check your fuses.
Rebel13 is offline
post #7 of 19 (permalink) Old 04-20-2012, 06:36 PM Thread Starter
Ok now where do i find the fuses?
post #8 of 19 (permalink) Old 04-20-2012, 07:24 PM
Left side cover.
Rebel13 is offline
post #9 of 19 (permalink) Old 04-20-2012, 07:57 PM
Take off the left side cover to expose the fuse box (usually called the junction box or JB here). There is a black plastic vertical strip about 3/4 or an inch wide that snaps off to expose the fuses. Just feel along the bottom edge of the strip for for a small lip and pull it out and up to get it off.
post #10 of 19 (permalink) Old 04-20-2012, 10:18 PM Thread Starter
Ok thanks any idea what size the fuse would be?
