tail light relocation confusion - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 04-11-2012, 12:17 AM Thread Starter
pittdave's Avatar
I'm lost on wanting to move the taillights. It their an 'official' kit or not?
What's the easiest way to go about this? I'm not good with drilling holes and so on so what's a noob to do??
Pittsburgh Dave
2001 VN750...old ride
2003 VN1600.. new ride
pittdave is offline
post #2 of 12 (permalink) Old 04-11-2012, 12:55 AM
They made factory relocation kits, but they're hard to find anymore. Basically it's a bracket that mounts over where your existing rear blinkers mount and moves it back about 10" or so so it doesn't get in the way of your saddlebags.
post #3 of 12 (permalink) Old 04-11-2012, 06:09 AM
i think he is talking about the brake/tail light.
but a kit to move the OEM tail light... never heard of it
post #4 of 12 (permalink) Old 04-11-2012, 11:09 AM
Crap, I WAS in 5th gear.
I used a Saddlemen license plate backet and cut off the rubber twist-lock portion of the sigals. There are better ways, but I was in a hurry. You would need to do some soldering and use shrink tubing, as the wiring would be exposed inside the rear fender. It's best to stay away from crimp connectors. I also jammed a section of a ballpoint pen in the hole where the wires go into the hub to act as a strain relief and to help keep the mounted signal from rotating too much if it vibrates loose.
Kelly2001 is offline
post #5 of 12 (permalink) Old 04-11-2012, 03:26 PM Thread Starter
pittdave's Avatar
Ok.. I think I saw something similar at Cycle Gear.. I almost bougght it, but wasnt sure it would be right. looking at the Saddleman, this looks the same. So I think I will go back and get it and go from there
Pittsburgh Dave
pittdave is offline
post #6 of 12 (permalink) Old 04-11-2012, 04:07 PM Thread Starter
pittdave's Avatar
looking at the pics again.. i think i want something that puts them with the tail light and not the license plate...ohhhh what to do
Pittsburgh Dave
pittdave is offline
post #7 of 12 (permalink) Old 04-11-2012, 04:29 PM Thread Starter
pittdave's Avatar
my bad in saying tail lights in the OP.. I want to move the rear turn signals. Whats available for us
Pittsburgh Dave
pittdave is offline
post #8 of 12 (permalink) Old 04-11-2012, 05:29 PM
turn signals is a completely different beast.. look at Knifemaker's sig line, cause the easiest method is going to be making your won.
post #9 of 12 (permalink) Old 04-11-2012, 09:07 PM
Heres a question thats right up the alley of this post. has anyone tried to install the vn2000 intergrated tail lights on an older 750. im thinking of going that way but wanted to see if any one has tried it already and whether they had any success or not?
mavrickvn750 is offline
post #10 of 12 (permalink) Old 04-12-2012, 02:01 AM
I got a set of LEDs and mounted them right to the tail light housing. Just had to drill two holes and run the wires along the wires for the tail light.
Spock
'93 750 Vulcan
DONE
Ear Shave
Re-Jet
EMGO Handlebar
MeanStreak Seat
Oversize Tires
Custom Skeleton Mirrors
Maintenance Free Battery
LED Halo Headlamp
LED Brake Light
LED Turn Signals
Hard Saddle Bags
Custom Plate Mount
Highway Pegs
Custom Skull Radiator Cover
All New Lines and Cables
Custom Neon Green Plug Wires
Iridium Spark Plugs
Kevlar Clutch Plates
PLANNED
Spline Lube
Fork Tubes Rebuild
Freeswilly is offline
