need help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 04-08-2012, 09:02 PM Thread Starter
need help
My headlight relay in my jb was bad so I switched over the blue wire into the empty slot on jb ad it worked this morning I pushed the start button and I get nothing but a click sound in the junction box I'm getting power to the switch relay and to the starter relay will my junction box make it do this
jwinkler is offline
post #2 of 6 (permalink) Old 04-08-2012, 10:59 PM
sounds more like a bad ground. it could be the junction box
post #3 of 6 (permalink) Old 04-09-2012, 04:08 PM
ifixf18s's Avatar
How did you determan you had a bad headlight relay? A charging system problem (stator) can also cause the headlight not to operate.
ifixf18s is offline
post #4 of 6 (permalink) Old 04-09-2012, 06:28 PM
I just posted a flow chart for testing the charging system last night...
check for VAC on all three stator wire.s, if you have any VAC, then the relay is getting power, next check for power coming out on the blue wire (i forget the pin number)
post #5 of 6 (permalink) Old 04-12-2012, 09:24 PM Thread Starter
I gettin no power to blue wire
jwinkler is offline
post #6 of 6 (permalink) Old 04-14-2012, 08:38 AM
I replied to your PM, lets get down to the bottom of your electrical gremlin.
