Chance to buy 01 750 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 04-06-2012, 03:15 PM Thread Starter
Rough and Tumble
Bruiser's Avatar
Hi all, I've got a chance to buy a 2001 vn 750 from a dealer where the owner left it behind, but they say it has an undiagnosed electric issue and the previous owner didn't want to pay to run it down, my question is if I drop 500 bucks on the bike where would I start after the battery? also since its been there for 3 years I'm sure the carbs and probably the tank need to be cleaned out really well, but what other issues should I look for once carbs and etc. have been done? I figure I'spend 5 on the bike then whatever else I spend is just an investment
Bruiser is offline
post #2 of 11 (permalink) Old 04-06-2012, 03:31 PM
First of all, any idea what the symptoms of the electrical issue were? Did the bike run? Was it a charging system problem? If the stator is bad the engine has to be pulled out to replace it. The Vulcan 750 has a very simple electrical system, the one exception being the igniter box. However, it is not known to fail often. If the bike looks good, and you can get it for $500, with a title, it's hard to go wrong, assuming you like working on things, and are not counting the cost of you own labor. If worse comes to worse, you should be able to recover the cost just from selling parts. The main thing to be careful about is dumping a bunch of money into it without knowing for sure what you are doing. Do as much as you can to make sure the engine and final drive are mechanically sound before spending a lot of money to repair electrical things.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is online now
post #3 of 11 (permalink) Old 04-06-2012, 04:07 PM Thread Starter
Rough and Tumble
Bruiser's Avatar
Thank you, these are all questions I will ask the shop. I personaly know those guys, so I'm pretty sure they wouldn't dump a crappy bike on me (if they know what the issues are to start with.) I am totally into wrenching on stuff and have a fair understanding of how things fit together when I look at them and I am looking for a project. How would you determine if the engine and shaft are sound without being able to start it?
Bruiser is offline
post #4 of 11 (permalink) Old 04-06-2012, 04:22 PM
put the bike up on its center stand, and spin the rear wheel with the bike in gear.. the engine should turn over... go through all the gears in this method... as for the splines.. remove the rear wheel... its the only way to check them any ways.
post #5 of 11 (permalink) Old 04-06-2012, 04:27 PM Thread Starter
Rough and Tumble
Bruiser's Avatar
cant post pics?
cant post the pics I have of this bike any tips fellas
Bruiser is offline
post #6 of 11 (permalink) Old 04-06-2012, 04:29 PM Thread Starter
Rough and Tumble
Bruiser's Avatar
as far as dumping a bunch of money into into it, no worries I dont have any
Bruiser is offline
post #7 of 11 (permalink) Old 04-06-2012, 05:30 PM
You need a couple more posts before it will allow you to post pics. $500 sounds like a good deal, I'd take it if I had the chance.
post #8 of 11 (permalink) Old 04-06-2012, 09:26 PM
slim did you forget about the positive neutral finder?
Bruiser, unless the tranny is already in 2nd gear or higher, you will only be able to try turning the engine over in first gear. The PNF prevents shifting into 2nd gear unless the rear wheel is already turning at some (unknown to me), speed.
You could also do a compression test or an engine leak down test.
Link to fergy`s spline lube, so you know what you are looking for :
https://www.vn750.com/forum/showthread.php?t=17274
post #9 of 11 (permalink) Old 04-06-2012, 09:41 PM
hmm must have forgotten, since my bike shifts through all the gears
post #10 of 11 (permalink) Old 05-03-2012, 12:47 PM Thread Starter
Rough and Tumble
Bruiser's Avatar
got it home today 200 bucks *no title* but since I work for a towing company we'll file a lien against it, and I'll have the title before I get it running
Bruiser is offline
