Iridium Plugs - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 04-05-2012, 09:49 AM Thread Starter
Captive New Yorker....
peterherrm's Avatar
Angry Iridium Plugs
Are these the plugs that everyone recommends for the 750:
http://www.ebay.com/itm/380426162401...ht_2497wt_1141
Is that a decent price. Do these plugs usually come pre-gapped for our bikes?
Not sure if there are different kinds of Iridium plug to choose from...
Thanks...
Pete Herrmann
Bought 4/2011 28k Miles,
New Rick's Motorsports R/R
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
peterherrm is offline
post #2 of 9 (permalink) Old 04-05-2012, 09:55 AM
Yes.
I got them cheaper at a local auto parts store but that isn't way off.
And you will have to gap them yourself. Its good practice to tripple check your gap.
post #3 of 9 (permalink) Old 04-05-2012, 09:57 AM
Did you read this post, just under yours?
https://www.vn750.com/forum/showthread.php?t=20893
post #4 of 9 (permalink) Old 04-05-2012, 09:57 AM
JM2001's Avatar
Yes,right plug. I got mine at Advance Auto for $6.99. They use stock number 7803 for the plug, comes out a cheaper price. They are pre-gapped but you should check them. The tip is so fine that it is risky re-gapping them.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #5 of 9 (permalink) Old 04-05-2012, 10:08 AM Thread Starter
peterherrm's Avatar
Yeah I saw it. I just figured I'd start a new thread because I know how much that annoys you.......
Pete Herrmann
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
post #6 of 9 (permalink) Old 04-05-2012, 10:19 AM
Yes, laziness does annoy me...;
post #7 of 9 (permalink) Old 04-05-2012, 02:55 PM
n2omike's Avatar
Do NOT try to re-gap those plugs, as those fine wires are too fragile. If they look to be in the ballpark, leave them alone. I wouldn't even recommend using a tool to check the gaps on them. Too easily damaged.
05 VN750
Iridium Plugs
Spline Lubed front/rear
ignition pickups gapped
AGM Battery
Relocated MOSFET R/R
Coaster Mod
Pilot Screws at 2-1/4 turns
Slipstreamer S-08 Windshield
F&S Saddlebags/Mounts
Luggage Rack
12V Outlet
Mustang Seat
sissy bar
Oversized Pirelli Front Tire
6k miles
PW50, XR50, TTR90, XR100, DT175 (2-smoker), CRF230F, XR250R (dual sported), XR400R 4 KIDS, LOL!
1966 mustang street/strip
4-speed, nitrous
[email protected] 135.6
n2omike is offline
post #8 of 9 (permalink) Old 04-05-2012, 10:35 PM
Originally Posted by M_Angell View Post
Yes.
I used to have a link to an NGK chart saved, but cannot find it right now.
As I recall, on NGK spark plug number DPR7EIX-9, the "9" refers to the plug gap measured in mm, and means 0.9mm.
In reality, I believe the DPR7EIX-9 plug comes pre-gapped between 0.8-0.9 mm, (0.032- 0.036") which is exactly what vn750 specs call for.
Checking the gap is fine, but adjustments should not be needed on these new plugs.
post #9 of 9 (permalink) Old 04-06-2012, 10:43 AM
Gemguy's Avatar
Bought iridiums a couple of years ago. Took them out of the box, never touched the tips, screwed them in and felt the increased power. Do not gap them or check them with a tool. If you bought the ones recommended for our bike just pop them in and enjoy.
~VROC~ # 389
Gemguy is offline
Tags
spark plug
