r/r and stator need help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 03-31-2012, 09:36 PM Thread Starter
The r/r plug A3 and G melted not the wire but the pin also stator was sopose to be replased in o6 but no proof but say so from dealer the stator plug conector infron of the battery box has been cut out and wired together. I need to know if I can get a new 3 pin conector for stator wire and a 6 pin for r/r. Also what would cause the G pin and the A3 pin to melt.
TheEDGE is offline
post #2 of 16 (permalink) Old 03-31-2012, 09:46 PM
I used the following to replace the 6 pin wiring harness @ the r/r. 3 of wires from the stator go into this harness along with 3 others. http://www.ebay.com/itm/VOLTAGE-REGU...72fad0&vxp=mtr
Grab a multimeter and run through the R/R and stator tests. They're quite easy to perform and will let you know where the problem lies. You can search @ the top of the site.
post #3 of 16 (permalink) Old 03-31-2012, 09:51 PM
stator wires use three bullet connectors. the six pin connector for the r/r can be found here http://www.electrosport.com/accessor...r-set-1-4.html
post #4 of 16 (permalink) Old 03-31-2012, 10:13 PM
Killer price on that.
post #5 of 16 (permalink) Old 03-31-2012, 11:18 PM Thread Starter
Thanks for the info on the conector.
Ok the stator test why do you have to test from the bullet connectors wouldn't it be the same at the six pin conector to the r/r?
One more thing since I'm asking I have a blinker problem left works but right comes on but dosnt flash any ideas ?
Thanks again guys for all the help
TheEDGE is offline
post #6 of 16 (permalink) Old 03-31-2012, 11:28 PM
They are usually done at the bullet connectors for ease of access. Some ditch them entirely and solder the wires together to remove them as a point of resistance. I just find it's easy to test from the bullet connectors. It wouldn't hurt to use some electrical contact cleaner on the bullet connectors while you're there.
post #7 of 16 (permalink) Old 03-31-2012, 11:53 PM
a) ease of access, b) the r/r connector means longer wire and more resistance, c) the R,R will still be in the equation.
post #8 of 16 (permalink) Old 04-01-2012, 07:29 AM
ifixf18s's Avatar
I always suggest reading out your stator at the R/R connector, If the readings are not correct then take your readings again at the bullet connectors, this would prove that the segment of wires between the R/R connector and the bullet connectors is good or bad.
Sorry to bust the bubble on the previous point made but taking the readings at the bullets due to a difference in resistance because the wires are a bit longer is a mute point. There sould not be a noticabe difference atleast with a standard multimeter. Theres not that much difference in length
ifixf18s is offline
post #9 of 16 (permalink) Old 04-01-2012, 08:42 AM
I forget I use a professional grade multimeter since I am issued the newest one once a year and the old ones are allowed to come back to my garage.
post #10 of 16 (permalink) Old 04-01-2012, 12:46 PM Thread Starter
Thanks again. Let y'all know what I find out.
TheEDGE is offline
