Brake Light Always on - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 03-29-2012, 05:18 PM Thread Starter
Crap, I WAS in 5th gear.
I already checked the switches.
My brake light is always on. When the front and back brake switches are activated, there is an ever-so slight increase in brightness, so I think the switches are OK.
Does anybody have any ideas
Kelly2001 is offline
post #2 of 4 (permalink) Old 03-29-2012, 06:09 PM
Patriot Guard Rider
The DEUCE's Avatar
You may need to adjust the nut on the rear brake switch.
VN750 #9300 & VROC #33453
The DEUCE is offline
post #3 of 4 (permalink) Old 03-29-2012, 06:39 PM
Member? ... check.
ZCraggRatt's Avatar
The rear brake light switch has a couple of bullet connectors. unplug one, and see if the light returns to normal. If it does, clean and adjust switch. If not, then the front brake switch may be dirty. Make sure the multi-pin connector leading to the front brake lever is in good shape and no shorts or dirty.
Good Hunting ...
~~C8>
ZCraggRatt is offline
post #4 of 4 (permalink) Old 03-30-2012, 01:14 AM Thread Starter
Found the short- red and blue wires under the seat were shorted so the taillight voltage was feeding the brake light circuit.
