Stator Replacement - External Oil Line - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 03-29-2012, 12:03 AM Thread Starter
I am in the process of replacing my stator. I was hoping to do it by just tilting the engine but I'm at the part where I need to move the external oil line. In the "stator replacement notes" it says to just bend the tab holding the oil line out of the way. My tab is a solid chromed piece and I just can't see how I am going to bend it out of the way and bend it back when I'm done. Has anyone got any good suggestions for this? Am I going to just have to pull the engine?
2002 Vulcan 750
Iridium plugs
AGM Battery
More upgrades to come!
crispycarp is offline
post #2 of 3 (permalink) Old 03-29-2012, 10:46 AM
Captive New Yorker....
peterherrm's Avatar
You can just bend it. I just did the same exact job, moving the engine out to remove the side cover. The chrome tab just bends right out of the way. When you bend it back into place when putting the cover back on it doesn't go back perfectly straight, but it's not noticeable, and it's WAY better then removing that whole oil line. You also do NOT have to remove the carbs.
Yes, you have to pull the engine to replace the stator, but you only have to move it two inches past the frame so you can slide the side cover off the shift tab. I never worked on a motorcycle before, and I just completed this job (well almost anyway). Feel free to PM me for any help. Follow the Stator replacement notes, they're great...
Pete Herrmann
Bought 4/2011 28k Miles,
New Rick's Motorsports R/R
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
peterherrm is offline
post #3 of 3 (permalink) Old 03-29-2012, 10:49 AM
peterherrm's Avatar
This is a good write-up also.....
https://www.vn750.com/forum/showthread.php?t=11369
Pete Herrmann
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
