battery - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 03-25-2012, 07:27 PM Thread Starter
battery
Has anybody ever used one of these batteries? Are they any good?
http://www.ebay.com/itm/AGM-KAWASAKI...d07e2d&vxp=mtr
Blessings!
Rich
mrseedsower is offline
post #2 of 12 (permalink) Old 03-25-2012, 07:55 PM
Looks like a cheap Chinese import. An AGM for under 30 bucks...? Just sounds too good to be true....and you know what they say about that.....
post #3 of 12 (permalink) Old 03-25-2012, 08:02 PM
JM2001's Avatar
Blessings!
Rich
I wouldn't. Not listed for a VN750, size won't fit, they don't give amps ( should be 14 ) or list CCA ( should be at least 190 ) and it is awfully cheap. JMO
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #4 of 12 (permalink) Old 03-25-2012, 09:00 PM
Drive less, ride more...
theauhawk's Avatar
A stout, reliable battery is one of the best ways to insure the long-term health of your bike's charging system.
Soooooo....if you are looking for a new battery for your bike, stick with a MF (sealed), AGM battery.....from a trusted, proven brand name like Yuasa, Westco, Deka, Sears "Diehard", etc. Make sure you chose a battery that is listed to fit our bike.
When you get your new battery, make sure the battery has been fully charged/prepped b4 you put it in the bike. You can simply trickle-charge it overnite if you are not sure of this (but use the appropriate size "smart" charger for your new battery--with a charge rating of 1.5 amps, or less). Of course, 1st add the appropriate fluid if the battery is shipped "dry".
When the bike is not in use (especially for extended periods of time), try to keep the bike's battery connected to one of the newer "smart" battery chargers--again, with a rating of 1.5 amps, or less.
'05 VN750
theauhawk is offline
post #5 of 12 (permalink) Old 03-25-2012, 09:10 PM
This Deka is a good one and is nominally rated at 15amp hours (ETX15L)
http://www.ebay.com/itm/Deka-ETX15L-..._Parts&vxp=mtr
The one in your link is only 12 amphour rated (BATTERY YTX12-BS)
post #6 of 12 (permalink) Old 03-25-2012, 09:25 PM
^ All that's good advise.... But you can also step into the 21st century and go with a lithium iron battery.
No real need to stick on a charger, unless you are off the bike for more than 4 months, as it holds a charge longer than an AGM.
http://www.shoraipower.com/default.aspx
It's been reccomended to get the 18 amp hour battery over the 14.
These batteries cost more, as most newer technologies are, but may outlive the AGM battery by twice the usual lifespan.
post #7 of 12 (permalink) Old 03-26-2012, 01:15 PM
don't do it!! look at the part number they listed:
AGM KAWASAKI ZR750 ZR7 ZX750 ZX7 VN800 VULCAN BATTERY YTX12-BS
It'S BS
post #8 of 12 (permalink) Old 03-26-2012, 01:28 PM
Patriot Guard Rider
The DEUCE's Avatar
It's a cheap Chinese knock off. I purchased 1 from eBay and the + terminal snapped off. The seller ended up sending me 2 more batteries at no extra charge with the same results before he refunded my money fully and I ended up with a Deka anyways.
VN750 #9300 & VROC #33453
The DEUCE is offline
post #9 of 12 (permalink) Old 03-26-2012, 02:33 PM
STAY AWAY!!!!
I bought one of those end of last season & it went to crap in a hurry. They sent me a replacement & it was just as junky. It came leaking acid or it was spilt when filling then packaged. Either way this is a waste of time battery.
Don Even Accept It If It's FREE!
I ended up buying this battery. TrueGel & love it.
post #10 of 12 (permalink) Old 03-26-2012, 06:29 PM
I use WestCos, because I already invested in 6 Battery Tender Jr.s, and have gotten used to hooking them up when I park the bike. I even had to install an extra outlet in the garage to plug them into (well, actually, I needed another outlet there anyway)
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
