Stall - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 03-23-2012, 02:45 PM Thread Starter
Stall
Anyone ever have their bike stall when turning the wheel right against the stop? Runs fine otherwise, and it doesn't do it all the time. Electrical? Throttle related??
750NE32 is offline
post #2 of 5 (permalink) Old 03-23-2012, 02:50 PM
My choke cable was too tight and would cause the choke to engage a bit when I was turning the bars one direction.
Worth going over your cables just in case.
post #3 of 5 (permalink) Old 03-23-2012, 02:57 PM Thread Starter
Hmmm...choke huh? Could be. I even had the tank off to look for a bad harness connection. Found a BIG connector under the tank thought it looked suspicious. I'll try the choke deal. THANKS!
750NE32 is offline
post #4 of 5 (permalink) Old 03-23-2012, 03:53 PM
HAWK
Ccspinner's Avatar
There has been a number of people stating this same thing. The problem was the ignition wires had a open on full right turn, may be in the switch or harness.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #5 of 5 (permalink) Old 03-24-2012, 12:31 AM
I had an issue with mine, endend up the wiring harness that goes around the front of the neck into the headlight had a wire rubbed through.
