GPS needs Juice - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 03-22-2012, 04:48 PM Thread Starter
Rider on the Storm
EasyRector's Avatar
GPS needs Juice
Right now I ride with my Garmin NUVI - held tightly in my RAM mount - until the battery dies out (which doesn't take long).
What's involved in getting juice to my Garmin? Right now I recharge it by attaching it to my car's cigarette lighter or to my computer (via USB cable). What's the best way to get power from my bike battery?
I can't imagine this would put much strain on the Vulcan's weak electrical system, although I have already added a couple of low-wattage LED Motolights.
EZC
EasyRector is offline
post #2 of 14 (permalink) Old 03-22-2012, 04:55 PM
there are several threads on installing an accessory plug ,just get one of the little adapters that plug into a cigarette lighter and has a USB outlet and you're set,The amp draw from your Garmin will be minimal and basically a non-issue.
post #3 of 14 (permalink) Old 03-22-2012, 06:48 PM
Big Dumb Viking
asbrand's Avatar
Send a message via AIM to asbrand Send a message via MSN to asbrand Send a message via Yahoo to asbrand
Really dude?
/me points to the sticky thread at the top of the Electrical forum:
https://www.vn750.com/forum/showthread.php?t=14496
-Az
http://www.asbrand.com
1989 Kawasaki Vulcan 750
Upgrades so Far:
Analog Voltmeter
PFIII Windshield
RAM GPS Mount w/Garmin GPS
Cigarette Lighter Power Adapter
Saddlemen's Classic Explorer Seat
Pro-Tac Driver's Backrest
LED Tail Light
LED Rear Turn Signals
Luggage Rack
Storage Trunk
Engine Guard w/Highway Pegs
Radiator Grill Cover
Turn Signal Relocation Bracket
Saddlebags
Floorboards
asbrand is offline
post #4 of 14 (permalink) Old 03-22-2012, 08:34 PM
You folks always making things so complicated...
Just get one of these....wire it right to your battery.
http://www.thegpsstore.com/Gilsson-G...min-P1718.aspx
Guess an inline fuse would be good to add to it...if there isn't one.
My gps is hardwired. Draw is not enough to worry about on the vulcan.
post #5 of 14 (permalink) Old 03-22-2012, 10:03 PM
That's a neat little cord for the Garmin,but he might want to charge his cell phone at some point in time but if powering the Zumo is all you are after,by all means the hardwired cord looks like the rte to go.
post #6 of 14 (permalink) Old 03-22-2012, 10:38 PM
I got that....but he did ask "What's the best way to get power from my bike battery?
I had a separate "ciggerette lighter" type plug on my bike for a cell phone, but hardwired the GPS. Plug in adapters can work loose, causing "unreliable" power to sensitive (or expensive) electronics. To me, hardwiring is the "best way" to power these items.
My iPhone cost me 45 bucks. My GPS cost over 10 times that.
You do need to make sure there is a proper amped inline fuse. There was one already built into the hardwire kit for my GPS. I am not sure about the one in the link I gave. I do believe Garmin does offer a hardwire kit for all their GPS units, but a quick search the one in the link was all I could find.
Wal-Mart sells a waterproof accessory plug in their truck and trailer section that would make a good choice if you want just a "ciggerete lighter" type plug. I suggest using a 15 amp fuse for it, as the Garmin plug has its own fuse. This way if you want to use the plug for something like a small tire pump you won't blow the fuse.
post #7 of 14 (permalink) Old 03-22-2012, 10:48 PM
There are also extra connectors inside the right side cover. And also there are some in the light bucket. You will need some bullet connectors.
post #8 of 14 (permalink) Old 03-23-2012, 07:01 AM
I've been happy with the cigarette lighter plug ins on the VN & Sporty, but I use them as Denny said, GPS, cell phone, trickle charger & whatever... My GPS (also a cheap Nuvi) will only do about 3-4 hrs. on its own battery charge, but I only use it when needed and then mostly on map setting, or if lost I hit home...lol...
So, that works for me, may not for anyone else...
post #9 of 14 (permalink) Old 03-23-2012, 09:08 AM
I used the leads behind the right side cover. Worked out great. I liked the 12v socket being hidden. I used some small adhesive backed wire clips to hold the GPS power wire along the frame up to the unit it's self. Simple & quick to set up the GPS for a ride, when I don't know where I'm going! lol
post #10 of 14 (permalink) Old 03-23-2012, 06:36 PM
n2omike's Avatar
There's an unused fused 12V wire behind the headlight that is perfect for powering a 12V adapter. That's what I used.
05 VN750
Iridium Plugs
Spline Lubed front/rear
ignition pickups gapped
AGM Battery
Relocated MOSFET R/R
Coaster Mod
Pilot Screws at 2-1/4 turns
Slipstreamer S-08 Windshield
F&S Saddlebags/Mounts
Luggage Rack
12V Outlet
Mustang Seat
sissy bar
Oversized Pirelli Front Tire
6k miles
PW50, XR50, TTR90, XR100, DT175 (2-smoker), CRF230F, XR250R (dual sported), XR400R 4 KIDS, LOL!
1966 mustang street/strip
4-speed, nitrous
[email protected] 135.6
n2omike is offline
