Oil leak from side cover - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 03-19-2012, 11:34 PM Thread Starter
Captive New Yorker....
peterherrm's Avatar
I've tried putting my side outer stator cover on twice now, but still have two oil drips from the bottom of the cover. I can't bare taking the damn thing off again and spending two hours cleaning all the silicone off. Does any one think it would be possible to seal it in this spot from the outside? I don't care what it looks like, I jut want to stop the leaks......
Pete Herrmann
Bought 4/2011 28k Miles,
New Rick's Motorsports R/R
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
peterherrm is offline
post #2 of 11 (permalink) Old 03-20-2012, 06:22 AM Thread Starter
peterherrm's Avatar
Snap
Pete Herrmann
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
post #3 of 11 (permalink) Old 03-20-2012, 06:50 PM
Crap, I WAS in 5th gear.
Not likely. I just use a carpet underneath where I park it in the garage.
Kelly2001 is offline
post #4 of 11 (permalink) Old 03-20-2012, 06:56 PM Thread Starter
peterherrm's Avatar
Lol. Doesn't everything on the bike behind the leak get covered in oil? I worry about my back tire getting oil on it.
Pete Herrmann
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
post #5 of 11 (permalink) Old 03-20-2012, 07:09 PM
That is certainly a concern. Just be more careful turning left. My rear wheel shaft seal failed at 300 miles, so I speak from experience! Seriously though, if it's leaking enough to get onto the back tire, you should fix it.
In my experience, once you let one minor leak go, it's easier to stomach additonal ones. I have a little different attitude than most since I commute every day and have too much other stuff going on right now. My bike is a tool, and as long as the minor leaks do not affect functionality, I will get to them when I have time. I have replaced my shift lever seal, but it started leaking again. I think oil is coming out of the stator wire opening now. It's not even one drip per day, so not such a big deal at this point.
post #6 of 11 (permalink) Old 03-20-2012, 07:18 PM Thread Starter
peterherrm's Avatar
Oh one drip a day, ok. This will drip one drop a minute at least.
Pete Herrmann
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
post #7 of 11 (permalink) Old 03-20-2012, 07:28 PM
Chucklehead
dragon159's Avatar
Remove the cover and check/clean the O-ring around the outside of the cover. A little nick will leak alot. I ended up using a little RTV until I could get a replacement, then dealt with the mess of cleaning it all off.
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #8 of 11 (permalink) Old 03-20-2012, 07:34 PM
Yep, you defintely need to fix it. If you use RTV the mating surfaces need to be TOTALLY clean and free from oil- and don't over-torque the fasteners
post #9 of 11 (permalink) Old 03-20-2012, 08:47 PM
Concert connoisseur
wib714's Avatar
mine is doing the same thing and has since I replaced the stator 2 years ago but it has gotten worse. the oil gets on the side of my back tire at highway speeds so I believe i'm just gonna drop the motor again and maybe do the stator cover mod while I'm at it, really not wanting tobut I cant take the leak anymore plus I ride in the rain a good bit which means the oil is going everwhere then! time to bite the bullet!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #10 of 11 (permalink) Old 03-24-2012, 12:51 AM
Striker1's Avatar
I guess I will join the oil drip club. Mine is just a few drops a day. And only when I run it.
1986 Vulcan 750
30,000 miles and counting
Castrol GTX 10w-40
WIX- Gold oil filter Pt.#1356 @ Napa Auto supply $8.00
Seafoam-2 oz. to every other tank of gas @ Napa-$10
Yuasa M/F battery- YTX14AHL-BS
Lubed Splines- Moly EP Grease, 1lb. tub $3.49-Autozone Pt.#561753
Sprayed U-joint with Liquid Wrench White Lithium Grease- $3.99 Autozone Pt.# 828796
Castrol Hypoy C 80w90 Gear Oil $5.99- Autozone Pt.#991558
NGK Iridium IX Spark Plugs, $8.99(x4)=$35.96 Autozone Pt.#088394.
Degoated
Striker1 is offline
Tags
oil leak , side cover
