Motorcycle Keys Stolen - Options?? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #1 of 23 (permalink) Old 03-17-2012, 12:58 PM Thread Starter
thebeginning's Avatar
So I had my motorcycle key stolen (only had one, yes my fault), and am wondering what my options are.
I have an 88 750.
Is there a way to get a key made or should I look into replacing the ignition system/starter and getting a new key with that?
thebeginning is offline
post #2 of 23 (permalink) Old 03-17-2012, 01:08 PM
HAWK
Ccspinner's Avatar
Call a locksmith and they should be able to look up the vin and make a key.
Alot cheeper that replacing the locks.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 23 (permalink) Old 03-17-2012, 02:50 PM
JM2001's Avatar
PM sent
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #4 of 23 (permalink) Old 03-18-2012, 09:14 AM
I have an 88 750.
If the key was stolen then maybe the bike will be next, I would change the ignition barrel and have a different key for it
Swagman is offline
post #5 of 23 (permalink) Old 03-18-2012, 05:19 PM
Captive New Yorker....
peterherrm's Avatar
I ordered an extra key from a Kaw dealer. Go to one and order two......
Pete Herrmann
Bought 4/2011 28k Miles,
New Rick's Motorsports R/R
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
peterherrm is offline
post #6 of 23 (permalink) Old 03-18-2012, 07:04 PM
Put a lock on the brake disc for security until you get the locks rekeyed.
post #7 of 23 (permalink) Old 03-18-2012, 08:28 PM
Concert connoisseur
wib714's Avatar
diy on rekeying helmet locks in my sig. pretty easy on the helmet locks but I have not done an ignition or tank lock although they should be pretty similar since it is the same key
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #8 of 23 (permalink) Old 09-23-2016, 02:37 AM
You might be able to go too your dealer and see if they can cut you one from the VIN on your scooter. Or you can go to a Locksmith and see if he can make a new key for the ignition. I've had them (the locksmith) do that on a boat I had when I lost the keys.
Damianmartin is offline
post #9 of 23 (permalink) Old 09-23-2016, 06:01 AM
Hey Damian, this thread is 4 years old, lol. Why don't you start your membership with a post in the newbie section.
OleDirtyDoc likes this.
post #10 of 23 (permalink) Old 09-23-2016, 02:39 PM
Maybe a dingo ate tchyo baby
