Pair of 55w driving lights OK? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 03-11-2012, 08:12 PM Thread Starter
I have a 94 and wondering if the charging system will handle the addition of a pair of 55w driving lights.
94-750 is offline
post #2 of 7 (permalink) Old 03-11-2012, 08:15 PM
flitecontrol's Avatar
I've read here that there is a "surplus" of about 75 watts with the stock light setup. So if you haven't installed a bunch of LEDs, you will have too much draw with two 55 attt lights.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #3 of 7 (permalink) Old 03-11-2012, 08:20 PM Thread Starter
WOW! Thanks for the quick reply.
Well RATS. I ride a lot in the dark and was hoping I could use the HID driving lights off my old dead Goldwing.
Oh well, I will convert the headlight to HID and "deal" with less light.
Thanks again
94-750 is offline
post #4 of 7 (permalink) Old 03-11-2012, 08:39 PM
I bought some 35w bulbs for my lites to replace the 55w ones.
post #5 of 7 (permalink) Old 03-12-2012, 12:19 AM
I wouldn't even use the 35 watt bulbs. That puts you right on the edge of the bikes electrical capacity, a little too close for me. I have installed a switch to cut off the headlights high beam when I use my electric gloves, because I noticed a slight voltage drop at the battery when I turned them on. These are older gloves, and most likely draw more current than newer ones, but they sure do work good. It was still charging, but possibly very close to overloading the system. I don't need a stator failure.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #6 of 7 (permalink) Old 03-12-2012, 08:46 AM
I used 25w bulbs & am very happy with the extra light output. There's always options but like it was mentioned, you need to be carefull not to overload the bikes eleectrical.
post #7 of 7 (permalink) Old 03-19-2012, 07:36 PM
Hmmm...I need to check the wattage on mine before I hook em up....they came with my bike but werent hooked up.
In Arizona ???
