Need help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 24 (permalink) Old 03-05-2012, 09:36 PM Thread Starter
Question Need help
Ok first off i'm new to this so I will try to put everything I know maybe someone can help (It would be very much appreciated)
I picked up an 89 Vulcan 750 a couple of weeks ago and it had been sitting for a while so after i cleaned the carbs and the replaced needle valve, it fired up.
Now the problem is rear right plug is not sparking, I swapped plugs and the same thing.My question is if my igniter is bad would all the other plugs work
cowboyup is offline
post #2 of 24 (permalink) Old 03-05-2012, 09:58 PM Thread Starter
Also to ad my old regulator wasn't charging so i bought a used one off of ebay not it only put out just barley over 12v, the battery is new too.
cowboyup is offline
post #3 of 24 (permalink) Old 03-05-2012, 09:59 PM
Does the rear plug on the left work? Try a spark plug wire.
Welcome to the group.
post #4 of 24 (permalink) Old 03-05-2012, 10:00 PM Thread Starter
Also to ad my old regulator wasn't charging so i bought a used one off of ebay now it only puts out just barley over 12v, the battery is new too.
cowboyup is offline
post #5 of 24 (permalink) Old 03-05-2012, 10:01 PM
Go to the verses and read up on how to check the stator.
post #6 of 24 (permalink) Old 03-05-2012, 10:02 PM Thread Starter
yeah all the other plugs work, and I changed all the plug wires.
cowboyup is offline
post #7 of 24 (permalink) Old 03-05-2012, 10:04 PM Thread Starter
I used a regular tester from harbor freight and according to it it tested fine.
cowboyup is offline
post #8 of 24 (permalink) Old 03-05-2012, 10:13 PM
If you swap the plug wires on the coil left to right will the other plug miss-fire?
post #9 of 24 (permalink) Old 03-05-2012, 10:23 PM Thread Starter
haven't tried that I will try it tomorrow.
cowboyup is offline
post #10 of 24 (permalink) Old 03-05-2012, 10:26 PM
When making test make sure that the batt has plenty of power. It looks like to me that you may have a bad coil.
Tags
igniter
