$1 Turn Signal relocation - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 07-30-2006, 09:50 PM Thread Starter
Once Banned
cegodsey's Avatar
Cool $1 Turn Signal relocation
Somebody look at my turn signal pics in the gallery under modifications. What kind of problems could I possible run into with this set up? I'm gonna seal the turn signal mounts on the inside of the taillight with silicone, to prevent water from getting in there. I've got some more pics to post of the process when I get totally through with it.
https://www.vn750.com/photopost/showp...to=185&cat=501
https://www.vn750.com/photopost/showp...to=184&cat=501
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #2 of 20 (permalink) Old 07-30-2006, 10:04 PM
tankist's Avatar
Send a message via Skype™ to tankist
looks good to me. what did you spend the dollar on though?
http://agrasyuk.googlepages.com/home
Anton Grasyuk
Wheeling, IL
tankist is offline
post #3 of 20 (permalink) Old 07-30-2006, 10:14 PM Thread Starter
Once Banned
cegodsey's Avatar
Had to get a couple of 6mm nuts and washers. Would have been free, if I had a few metric nuts laying around.
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
post #4 of 20 (permalink) Old 07-30-2006, 10:20 PM
Can't say I see any problems you'd have.
Maybe some additional support along the insides of the tail light housing (1/8" steel plate or similar) just so there's less of a chance of the housing breaking if the turnsignals are bumped a little too hard.
But as it looks, it should be just fine.
post #5 of 20 (permalink) Old 07-31-2006, 01:03 AM
Uber Member
the only thing i can see is if you put a rack on, they might get a lil rough lovin from the luggage you put on that. other then that should be fine if your careful.
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #6 of 20 (permalink) Old 07-31-2006, 02:51 AM Thread Starter
Once Banned
cegodsey's Avatar
I never go far enough to need a rack. My wife bought me some saddlebags, and the turn signals were in the way.
The plastic is unexpectedly rigid. I checked that before I cut the holes. Probly won't support the bike on its side, but the fender won't get all banged up like it would if I used a license plate relocate. I'll wait until the first time I break it before I use steel to back it up. Steel is harder to cut than plastic, and all my tools are primarily designed for woodworking. Besides, I've gotta go to work tomorrow, and I don't have a lot of time left for this project!
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
post #7 of 20 (permalink) Old 07-31-2006, 07:17 AM
Geek
rnewell's Avatar
That looks great ! I was thinking of doing that but not to relocate. I was thinking of adding 2 more lights, for more visibility.
Ron from Jersey
HellFire windshield
Kaw extended backrest
Cobra exhaust
Re-located stator wires
Side bags
15,000 Miles July/2012
It's PAID OFF ! May 2009
rnewell is offline
post #8 of 20 (permalink) Old 07-31-2006, 02:52 PM
Loran in Npvl IL's Avatar
Other VN750 owners have done this as well without problems (and without any steel other than the bolt/nut I think). Your pictures are very nice. If someone has a kawasaki relocation kit laying around, maybe you could borrow the "C" (almost a "c") brace to use as a pattern (the one you would make would be a little thinner).
Deuce (Loran Naperville IL)
2003 VN750
- Corbin seat w backrest
- Progressive suspension.
- Kury iso goldwing grips
2 1983 V65 Magnas
Loran in Npvl IL is offline
post #9 of 20 (permalink) Old 07-31-2006, 04:24 PM
Geek
rnewell's Avatar
Can you post a side pic ?
Ron from Jersey
HellFire windshield
Cobra exhaust
Side bags
rnewell is offline
post #10 of 20 (permalink) Old 09-03-2006, 09:05 PM
kait's Avatar
Hey Cegodsey,
I am about to win a new set of bags with the kaw supports on ebay, but it doesn't come with the relocation kit. Could you send me directions (in small easy to understand words and sentences, using as few EE terms as possible) for the relocation you did? and also, what did you do about the helmet locks? I don't use mine very often, but I would like to be able to keep 'em if I can. thanks, kait
My Blog:
http://kaitbr.blogspot.com
VROC #21146
Mods and other stuff:
final drive splines lubed 8/06
replaced broken speedometer cable (5194 miles) 9/06
Vehicles:
95 S-10 Blazer 187K miles (Black and Silver)
01 Kawasaki VN750 3300+ my miles, 5300+ total miles (Black and Silver)
04 John Deere L118SE Riding Mower w/ snow plow (John Deere green and yellow)
kait is offline
