New MF battery - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 25 (permalink) Old 02-19-2012, 07:27 PM Thread Starter
Just a regular guy
Chris32250's Avatar
New MF battery
I just got a Yusa MF battery online and the instructions are kinda vague. Is there anything special I should know?
"Pain is weakness leaving my mouth! *&%^$ that hurt!"
Promo code for 10% off at leatherup.com..... 55634
===2001 Vn750====
New Chrome agm battery
Ears shaved
Sportster pipes
12v adapter installed
Chris32250 is offline
post #2 of 25 (permalink) Old 02-19-2012, 07:44 PM
1986vn750's Avatar
Not that i know of. Mine said no pre-charge needed. You could if you wanted just give it a 2amp charge for a few hours, and install. Mines almost a year old, havnt charged it once. even after sitter 2 months in the winter, the bike spun over and fired up instantly.
1986 Vn750
18,800 miles, and counting
Bone Stock
New cam chain tentioners
all fluids changed
Spline Lube
windshield
Engine Guard
B-stone S11 RWL-stock sizes
*wanted*
New grips
2001 Vn750
13,100 miles, and counting
spline lube
Bridgestone S11 100/90
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
1986vn750 is offline
post #3 of 25 (permalink) Old 02-19-2012, 10:13 PM
Love My Baby
rubyrick's Avatar
Mine needed to have the electrolyte installed and then a full trickle charge applied. Even if you've never done that before, it's easy. Once you remove the strip of tape that covers the battery you will see the sharp protrusions inside each chamber that will poke through the electrolyte chambers once you push down on them. It won't spill out, don't worry. Just place the battery on a strong level surface that doesn't wobble and where you won't accidentally knock into it while it settles for a while. Also, charge the battery before you place the permanent cover on. Just place the cover strip over the holes without pushing down on it, until the charger indicates that the charge is complete.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #4 of 25 (permalink) Old 02-20-2012, 04:47 AM
I don't know about the Yuasa battery, but I have had problems with a couple of MF batteries that had to be filled, then sealed. When I get a MF battery, I want it ready to go. That is why I get WestCo batteries. I've had excellent luck with them. I did get one that was DOA, I called them, and 2 days later, had a new one on my doorstep, no questions asked. Can't beat that. Haven't had any problems with the replacement. I used to charge new motorcycle batteries with 1 amp for 24 hours before I installed them if possible, now that I have a Battery Tender Jr. for all of my bikes, I go ahead and install the battery, including the pigtail for the Battery Tender, then leave it connected for 24 hours. On a new battery, the light should turn green right away, and according to the instructions that came with the battery tenders, that means fully charged.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #5 of 25 (permalink) Old 02-20-2012, 10:18 AM
cglennon's Avatar
Yuasa is a good brand and quality product. My Yuasa is going on its 4th year, without issue. No indication that it will give up the ghost anytime soon. Yes, their instructions are not the best (language barrier is my guess why). Follow Rubyrick instructions or hit Youtube for a video.
Chris Glennon - Portland, OR
cglennon is offline
post #6 of 25 (permalink) Old 02-21-2012, 10:31 AM Thread Starter
Just a regular guy
Chris32250's Avatar
Ok, so I filled and charged the battery.... It doesn't fit. I double checked and it seems to be the correct one. the only difference I see is that is bears the #YXT14-BS instead of #YXT14AHL-BS. I tried again searching and evertime I look up the number recommended it comes up without the "AHL". Is this a common problem?
===2001 Vn750====
Ears shaved
Sportster pipes
post #7 of 25 (permalink) Old 02-21-2012, 10:50 AM
JM2001's Avatar
The difference should be in the height. The L is 5 1/4 x 3 1/2 x 6 1/2. The B2 is 5 1/4 x 3 1/2 x 7
Check this site for cross reference. You can scroll down and click on ETX 15 and it will show the B2 battery
http://www.tristatebattery.com/produ...roducts_id=977
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #8 of 25 (permalink) Old 02-21-2012, 11:04 AM Thread Starter
Just a regular guy
Chris32250's Avatar
My problem is width, I need about 1 more inch....
===2001 Vn750====
Ears shaved
Sportster pipes
post #9 of 25 (permalink) Old 02-21-2012, 11:14 AM
JM2001's Avatar
All I can say is that a 5 1/4 x 3 1/2 x 6 1/2 battery fits perfect in my battery box. I just went down in my basement and measured the battery.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #10 of 25 (permalink) Old 02-21-2012, 11:16 AM
Don't we all.......
Sounds like you got the wrong battery. Call them up and have them fix it. (did you order the wrong one?)
