Removing Rear Turn Signals - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 02-18-2012, 12:03 AM Thread Starter
Crap, I WAS in 5th gear.
Can somebody tell me how to get the rear turn signals off to relocate them? They seem to be stuck. I've built hardware that's in orbit an even floating around the solar system, but can't figure out how to get these off. Without breaking them that is. I assumed they'd just pull out after removing the screw.
Kelly2001 is offline
post #2 of 13 (permalink) Old 02-18-2012, 12:21 AM
You have to turn them, i forget if it's left or right, then they pull out.
post #3 of 13 (permalink) Old 02-18-2012, 12:45 AM
1986vn750's Avatar
yeah, just turn them about 90 degrees (i think either direction) and they pop right out.
1986 Vn750
18,800 miles, and counting
Bone Stock
New cam chain tentioners
all fluids changed
Spline Lube
windshield
Engine Guard
B-stone S11 RWL-stock sizes
*wanted*
New grips
2001 Vn750
13,100 miles, and counting
spline lube
Bridgestone S11 100/90
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
1986vn750 is offline
post #4 of 13 (permalink) Old 02-18-2012, 12:56 AM Thread Starter
Thanks Guys
So to do a turn signal relocation, you usually hack off the end that has the locking feature? This has turned into a bigger job than I thought.
post #5 of 13 (permalink) Old 02-18-2012, 04:21 AM
MaDeInSin's Avatar
Kelly-
Where are you trying to relocate them to? Do you have relocation brackets?
Getting them off is pretty simple.. Just as the other members have said.. You take the screw out and you can turn them either direction about 90 degrees and they pop out..
If you have purchased a relocation kit then they will go into the kit the exact same way.. You don't have to shave anything off.. There are other MODS that you can look up if you don't have the relocation kit like Kanuck69 has in his siggy...
Give some more info on what your trying to do and what tools you have to do it and I am sure we can help you out more.
Accomplishments;
Changed Final Drive Fluid
Iridium Plugs
NGK Spark Plug Wires
Bridgestone Spitfire Tires
Maintenance Free Battery
Lubed the Spline
Shaved and Coastered
Under Tank Air Filter
Re-Jetted
Vn900 Seat Mod w/ Honda 1100 Backrest
Rebuilt Petcock
Custom Mirrors
Custom SaddleBags
LED Taillight
Heads Up Voltage Monitor
Upcoming: Change front fork Seals & Oil, install highway pegs & floorboards
MaDeInSin is offline
post #6 of 13 (permalink) Old 02-18-2012, 08:41 AM
If you're looking to bolt them on somewhere else, they make aftermarket ones that will do that.
post #7 of 13 (permalink) Old 02-18-2012, 03:56 PM Thread Starter
I've got the Saddlemen license plate bracket. Going to cut off the end to make it flat and use a pen tube through the bracket hole. I have the LED ring brake lights inside the turn signals already and want to keep them.
post #8 of 13 (permalink) Old 02-18-2012, 08:38 PM
The signals pop right off after you remove the Phillips screw. That's what I had problems with. Even back when the bike was almost new, and I installed the Kawasaki saddlebag/turn signal relocation brackets, I stripped out the heads on both those screws. And I was using the right size screwdriver. I don't know what they are made of, but it sure doesn't seem like metal. When I finally got them out, I replaced them with Allen head bolts and flat washers.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #9 of 13 (permalink) Old 02-19-2012, 12:35 AM
2000 VN 750 Senior Member
That is why you need the right tool, Impact Driver with a #2 bit. Place it over the screw head and then just one tap on the end. The screw will be loose and ready to come out fully intact with just a few hand turns of a screwdriver. Check this out:
http://www.harborfreight.com/impact-...ase-37530.html
It is only $6.99 and they have an even cheaper unit at $4.99. You can spend much more but it isn't necessary. This tool sure saves time, effort and eliminates rounding out screw heads. The driver will also take regular socket heads for stuck nuts and bolts. Its a great tool to have around just for saving the mental anguish a stuck screw creates during a simple project.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
post #10 of 13 (permalink) Old 02-19-2012, 02:33 AM Thread Starter
An impact driver is almost required to take the carbs apart.
