Stator replacing mod - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 01-30-2012, 12:35 AM Thread Starter
I was working on this mod. I plan on drilling and tapping the holes before cutting the engine plate. All I have for now is the card board ideas. Here are some pics. I plan on using aluminum for the plates. Add ideas or short commings on this idea.
The black dots is where the small bolts will be placed.
The black line is where the engine cover will be cut. It is the same as where all others cut it. Bolt will be placed before any citting is done. This will ensure a better line up fit.
ID:	4260   Click image for larger version
ID:	4261   Click image for larger version
ID:	4262   Click image for larger version
ID:	4263   Click image for larger version
post #2 of 11 (permalink) Old 01-30-2012, 11:09 PM
Young Gun
kc_matt's Avatar
I really like your thinking on this! A couple thoughts-
Is the case thick enough to hold many threads? I suppose with three bolts on each side of the cut you may not need much.
You'll probably need to grind the ribs on the inside of the case cover to allow clearance for the bolt heads and wires...
Is there any reason the two plates couldn't be connected in the center (covering the three inner bolt holes, still leaving the shaft bolt accessible). Might help even more with strength and alignment.
You say you're going to use aluminum, any reason steel won't work?
I'm in the middle of a Tuxedo stator mod, just prior to cutting the case. This is very intriguing! Hell, maybe I should try it, if it just won't fly I guess I can always Tux it!
1990 VN 750
First (hopefully last) time in the shop:
Carb rebuild New brakes front and back New radiator fan
I've done:
Spline Lube New (used - non-leaky) Gas Tank New Fork Seals New Pirelli tires New Yuasa Maintenance Free Battery
Fresh Dexcool coolant Upgraded Shunt-type R/R (Relocated) Headlight Bypass Stator tested - PASSED
Clutch Swap - EBC Street Racer Frictions with new eBayed steels ACCT to MCCT conversion
kc_matt is offline
post #3 of 11 (permalink) Old 01-30-2012, 11:48 PM
HAWK
Ccspinner's Avatar
There is already a company that will do this for you. Don't rember the name but somebody will be chiming in soon.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #4 of 11 (permalink) Old 01-31-2012, 12:50 AM Thread Starter
I like the idea of connecting the two pieces together. I kind of thougth that aluminum may not bend too easy. But steel will work.
I plan on using black allen head bolts and lock tight them in.
post #5 of 11 (permalink) Old 01-31-2012, 12:52 AM Thread Starter
Yeah, but they want 400$ or more.
I did the stator replacement and it was not too bad. Just time consuming.
post #6 of 11 (permalink) Old 01-31-2012, 12:52 PM
TOC www.toc manufacturing.com
post #7 of 11 (permalink) Old 01-31-2012, 04:10 PM
Since this is a new thread on the subject, I feel a need to post my opinion about it. Assuming you don't really care about looks, I see nothing wrong with the mod, but I STRONGLY suggest removing the complete cover from the engine and doing the cutting and grinding in a safe place, where metal particles will not get into the engine. Just a few small metal particles in the oil can destroy an engine. In fact, IMO, doing this mod with the cover on the engine will result in more damage to the engine than running the K&N pod type filters. They will at least stop the big stuff. I am posting my opinion for anyone who may find it useful. Since it is your bike, it is your choice, but you are doing it at your own risk, and IMO, the risk is considerable.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #8 of 11 (permalink) Old 01-31-2012, 06:36 PM
Concert connoisseur
wib714's Avatar
Im with you on this one, plus I think it would be so much easier to work with!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #9 of 11 (permalink) Old 05-09-2012, 05:19 AM
Ndr
Any progress on this Modification? I'd love to see the finished product. How well did tapping and screwing into the case work out?
Ndr is offline
post #10 of 11 (permalink) Old 05-09-2012, 11:56 AM
i completely agree that taking the cover off when doing this mod is best so as to keep all shavings out of the engine, however, there in lies the conundrum.
Don't you have to pull the motor to get the cover off?
If that is the case then why is this mod necessary?
Do stators go out that much?
So that being said i believe it is a great idea and my only other question is why didn't kawi think of it in the first place?
