cheap battery monitor - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 12-30-2011, 05:32 PM Thread Starter
I was considering ordering the Signal dynamics Heads-Up Voltage Monitor for about 30 bucks.
I know that with my electronics background I could build one cheaper, so I was browsing my local electronics supply store for parts when I happened to come across this sitting in the isle with all the build it yourself kits.
http://www.vellemanusa.com/products/view/?id=525836
I grabbed it and took it home since it was cheap and gave it a test.
Here are the rough voltage results:
red: battery voltage is low (below 10.8 volts)
green: battery OK (10.8-12.95 volts)
Slow pulsing (green): battery OK or charging (12.95-14.8 volts)
red blinking: battery is being overcharged (above 14.8 volts)
The LED is tiny, can be easily seen in daylight, but not overly bright, which is fine with me since I don't need to be blinded at night by a blinking LED pointed at my face.
It works well enough for what it is intended to do, which is give me a quick heads up if the charging system is not working properly.
I plan on un-soldering the LED and soldering a set of wires between the LED and the PC board. I picked up a LED holder and will be mounting the LED on the dash as suggested in other posts. The PC board will get wrapped in rubber tape or heat shrink and fastened either in the headlight bucket or some other inconspicuous place. The 2 wires to power the logic board will be wired in to the driving lights so it will be off when the ignition is off.
For about half the price of the Signal Dynamics version, I am glad I found this little gem. I will post pics once the install is done.
post #2 of 13 (permalink) Old 12-30-2011, 06:32 PM
So basically it says that when your bike is running, and your R/R is pssing volts to your battery...i.e. "charging" your battery, it will blink green....as long as the voltage is between 12.5 and 13.5 volts.
Sorry but if your getting only 12.5 volts, your battery is NOT charging. A bad stator can still show 12.5-12.7 volts. So you can have a malfunctioning stator and the light will blink green telling you nothing is wrong. Many times the bike will put out over 14 volts....and no, the battery is NOT getting "overcharged"..
Spend the extra money and get a usefull gauge. One that actually has a digital readout that tells you exactly how many volts are going to your battery being the best pick.
Sorry.
post #3 of 13 (permalink) Old 12-30-2011, 06:48 PM Thread Starter
The voltages posted were what I was seeing on a quick and dirty test, which is why I used the word "rough". I will test it on the bench tomorrow and report what my findings are. Either way, I can adjust the trigger voltages for each output change of the LED.
I regularly check voltages with a good quality digital meter during warm up of the bike to see what is going on. The intent of this LED is to just give me a "heads up" if something is not functioning normally.
post #4 of 13 (permalink) Old 12-30-2011, 07:19 PM
Well that be different if you can fine tune each voltage range for each indicator.
I do like the fact there is only one light and not a bank of them as some LED units I have seen.
Still rather just have a simple digital readout. No guess work ... 13.8 volts means 13.8 volts....
post #5 of 13 (permalink) Old 12-30-2011, 08:29 PM Thread Starter
Revised Voltages in first post....ok..so the initial test was way off
compare to Signal Dynamics heads up voltage monitor output specs:
Flashing Red - Below 12 VDC
Steady Red - 12.1 - 12.5
Steady Amber - 12.6 - 12.8
Steady Green - 12.9 - 15.24
Flashing Green - Voltage Above 15.25 VDC
Velleman battery monitor MK189:
I like the simplified scale and colors/flashing just seem to make more sense IMHO
post #6 of 13 (permalink) Old 12-30-2011, 10:14 PM
Chuck A.'s Avatar
Signal Dynamics Heads Up voltage monitor Is a good product. Like mine just fine. And a good place to mount the LED in through the back/top of the light bucket. With the limited space, I'd be more out to put an oil pressure gauge on before a volt gauge. As long as it's green you have battery juice. All we have for oil pressure is a light and that don't tell you what oil your internals are getting.
Chuck A. is offline
post #7 of 13 (permalink) Old 12-30-2011, 10:20 PM
Smile oil pressure guage
Originally Posted by Chuck A. View Post
Signal Dynamics Heads Up voltage monitor Is a good product. Like mine just fine. With the limited space, I'd be more out to put an oil pressure gauge on before a volt gauge. All we have for oil pressure is a light and that don't tell you what oil your internals are getting.
Is there any way possible to add a guage to the VN750 ?
WilliamTech
post #8 of 13 (permalink) Old 12-30-2011, 11:35 PM
I have a (believe it or not) digital voltmeter mounted to the handlebar clamp with double sided tape. Being digital, and plastic, I don't know how long it will last, but I've had it for over a year. How accurate it actually is I don't know, but the display is very accurate, using four numbers, it measures voltage to the hundredths. I have it connected directly to the battery, to get the most accurate reading. Being digital, it has the same issue I find so distracting with digital multimeters, it constantly fluctuates, and when it does, it's not a tiny barely visible movement of the needle, but a complete change in numbers. However, it is entertaining to watch the last 2 numbers keep changing up and down as it idles, and watching all the numbers change as you ride it through town. Once you get used to it's readings, you would quickly notice a difference if they changed very much. I think I paid about $30 for it online.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is online now
post #9 of 13 (permalink) Old 12-31-2011, 04:18 PM Thread Starter
I installed the battery monitor today. I installed the LED on the dash just to the left of the ignition switch. Ran the 3 LED leads to the headlight bucket (through one of the harnesses). I wrapped the PCB up with rubber tape to insulate and also covered it with electrical tape and stuffed it in the back of the headlight housing. I tapped into the dash lights and wired it up. Buttoned it up and tested everything. I am happy with the install and with the performance of the monitor.
With ignition on(bike not running) and at idle it stays lit green.
At 2K RPM and above, the LED flashes green.
I turned off the engine with the kill switch and left the lights on to see if it would stay lit green, which it did. I see that when the starter is engaged and the bike cranks the engine, the LED will after a few tries turn to red, but only if you really stress the battery.
I am happy with this circuit, and although it doesn't display a voltage, I can get a general idea if the system is working. For me that is just some peace of mind after constantly reading posts about failed charging systems. If I am cruising and that little LED isn't Flashing green, then I know not to shut down the bike until I am somewhere safe....hopefully home.
post #10 of 13 (permalink) Old 01-02-2012, 09:42 PM
I recommend that along with a device to monitor the battery voltage, that you put an "off" switch in the headlight circuit. I already have one, which I installed so that I could turn the headlight off (in the daytime) if the battery voltage dropped too low while using my electric gloves. This could also be used to save power if the charging system failed. The headlight uses way more power than anything else, and there is no reason to waste that power if you are running the ignition off the battery alone. Also get and carry another key, so you can fill up the gas tank with the engine running, and avoid having to use the starter. A fully charged battery will power the ignition system for over 1000 miles.
1979 Vespa P200E
