starter relay - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 07-25-2006, 07:22 PM Thread Starter
starter relay
Just want to double check my thoughts. Last night my Vulcan wouldn't start unless I jumped the seleniod and pushed onto the starter button at the same time. This is definatly the starter relay, right?
Ignition switch keys up the lights, so thats working. Fuses are healthy. Dont knkow what else it could be.
Any insight will be appreciated.
Grasshog30 is offline
post #2 of 9 (permalink) Old 07-25-2006, 07:27 PM
Once Banned
cegodsey's Avatar
Battery.
You don't have to push the start button. Just jump the solenoid. What battery do you have?
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #3 of 9 (permalink) Old 07-26-2006, 02:58 AM Thread Starter
My info on the problem
The batery that I have is a 14la2. It is in good shape and healthy.
Jumping the starter seleniod is just kicking over the engine, but nothing more.
It is only when I have my finger on the start button as well as jumping the seleniod that the bike will actually fire over.
post #4 of 9 (permalink) Old 07-26-2006, 03:25 AM
Ernie's Avatar
Send a message via MSN to Ernie
That sounds weird. Jumping the solenoid should allow the bike to start as long as the ignition is switched on. All the starter button does is energise the plunger inside the solenoid which makes the contacts.
Something must be wired up wrong if the bike only fires if the start button is pressed.
1991 BMW K1100LT
1980 Suzuki GS1000G
Ernie is offline
post #5 of 9 (permalink) Old 07-26-2006, 03:30 AM
Once Banned
cegodsey's Avatar
That sounds like a wiring problem. The start button should only kick the solenoid if certain conditions are met (in neutral, in gear with clutch in, ignition switch on). Oh, how are you jumping the solenoid? Nut to nut?
In any case, can you give us more info about your bike? year model, how long you've had it, new or used, mileage, any modifications, any previous trouble, etc...
Like the other Ernie just said, "Jumping the solenoid should allow the bike to start as long as the ignition is switched on."
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
post #6 of 9 (permalink) Old 07-26-2006, 11:06 AM Thread Starter
starting problem
My bike is a 1995 Vulcan 750.
The wiring other than needing to change the kick stand switch is stock as the day it came off the showroom.
I am jumping the post on the seleniod with a good old fashioned screwdriver.I will kick the motor over ,but thats it the motor just rotates. It's not until I use a combination of the two. The start button and jumping the seleniod the I actually get ingnition. As far as I can telll there isn't a loose conection or break in the wiring.
post #7 of 9 (permalink) Old 07-26-2006, 01:03 PM
hgree's Avatar
If there is a problem with the kick stand switch is probably why you are having to hit starter switch. The kick stand jumper is not allowing motor to run without kick stand and starter jumpers combined.
Out of VN750s...
On to bigger and better things!
1997 Black & Silver ***SOLD***
Insurance Replaced: 08/25/2008
Mileage: 10/29/08- 4644 miles
Son's **Sold: In the ARMY & married $$$**
1995 Teal Green
Purch 08/17/2007: 14,240 miles
10/29/2008: 17,640 miles
Wife's **Sold: shoulder injury**
1999 Gray/Black w/Fairing
Purch 06/22/08: 18,160 miles
10/29/2008: 19,889 miles
hgree is offline
post #8 of 9 (permalink) Old 08-09-2006, 11:12 AM Thread Starter
thanx for the help
It turns out the problem was the side stand safety swith. I should have know. I have had to replace the thing for the same reason in the past.
I do apreciate the advice and help that everbody has given me.
post #9 of 9 (permalink) Old 08-09-2006, 12:53 PM
Once Banned
cegodsey's Avatar
Thanks for the update!
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
