How much light flicker is normal? Worried stator might be going - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 10-25-2011, 11:37 PM Thread Starter
Git-R-Done!
AZ Kev's Avatar
I've noticed lately at night (when it's easier to see) that my lights - headlight, neutral indicator, etc - seem to be flickering more than they used to. Could it be sign of my stator starting to go?
I checked my battery connections and otherwires as best I could, and they all seem to be ok.
AZ Kev
Arizona Kev
1989 VN750
7800 orig mi when purchased Jan 2011
Turned 11,000 mi Nov 2011
Saddlebags
Taillight relocation kit
Chad's highway peg mounts
Emgo Pegs
Aftermarket mirrors
Dunlop D404's
Otherwise, all stock
"But it's a dry heat - like the inside of an oven"
AZ Kev is offline
post #2 of 5 (permalink) Old 10-26-2011, 09:06 AM
The lights, most notably the headlight, may be a bit dimmer at idle, but nothing should actually "flicker". Check the voltage across the battery terminals with the bike running at 2000-3000 rpm. You should get 13.5-13.9 volts. Also check both battery terminal connections, and all the ground connections. Make sure everything is nice and tight. Also check the 3 bullet connectors in the yellow wires going from the stator to the R/R. Mine were burned. I eliminated the connectors and soldered everything together.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is online now
post #3 of 5 (permalink) Old 10-26-2011, 04:56 PM
I have had a few issues with lights... LB Headlight ocassionally going out on right turns, turn signal ocassionally refusing to blink.. sparadic indicator light blink etc. I found cleaning electrical connections near the bars seemed to have resolved stated issues, and of course dielectric grease in the connectors.
Good Luck
WilliamTech
post #4 of 5 (permalink) Old 10-27-2011, 12:55 PM Thread Starter
Git-R-Done!
AZ Kev's Avatar
WT - when you say "near the bars," what exactly do you mean? I am assuming it's not like near the nudie bars or something, right? Lol
I am thinking you mean where they slide together...?
Thanks -
AZ Kev
Arizona Kev
1989 VN750
Saddlebags
Emgo Pegs
Aftermarket mirrors
Dunlop D404's
AZ Kev is offline
post #5 of 5 (permalink) Old 10-27-2011, 03:47 PM
Crap, I WAS in 5th gear.
After you check all your electrical connections, especially the ground(s,) and have checked your stator resistance, you may need to look at the battery-- there might be something funky going on like an intermittent partial short or open.
Kelly2001 is offline
