Ignition Key - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 09-09-2011, 06:07 PM Thread Starter
Mike DeAngelo's Avatar
Smile Ignition Key
I lost the key and thought I could use the rear helmet lock to have a key made. I was told the key may not work in the ignition once it's cut. I understand why but am wondering if this is the case with my 95 Vulcan 750. Is it easy to take the console apart and take the ignition out so I can have a key made?
Thanks for your help.
Mike DeAngelo is offline
post #2 of 4 (permalink) Old 09-10-2011, 04:11 AM
the key should be the same
and as far as getting the ignition switch out.. its a mediocre task
post #3 of 4 (permalink) Old 09-10-2011, 08:19 AM
JM2001's Avatar
The key will work. The key code is stamped into the bottom side of the helmet lock. Any dealer can cut a key from the code. Cost here is $ 9.00 iirc.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #4 of 4 (permalink) Old 09-14-2011, 08:31 PM Thread Starter
Thank you MUCH!
Thanks for both our your help and guidance. It's greatly appreciated!
