What stator to get? ElectroSport, Electrex, OEM, or Rewind? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 07-14-2006, 11:56 PM Thread Starter
Uber Member
Ok started looking for a new stator, low and behold i have 5 options...
Electrosport ESG050- $119 +$15s/h
Electrex G05- $101.2 + unknown s/h
Electrex G105 (this is the high output "30% more")- 119+Unknown s/h
Oem- $250 depending where you shop
Rewind- about $100-150 to have it done, do it yourself for less then $50
I will be attempting a new mod that i will make myself that should negate almost all the engine heating issues...but still want the highest output.
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #2 of 18 (permalink) Old 07-15-2006, 12:39 AM
Once Banned
cegodsey's Avatar
Read up on it. I think I remember reading something about a Honda stator that used two smaller wires instead of one big one. (More surface area for the electrons?) It gave a much higher output. If you are going to build your heat block in such a way that the stator can be removed without moving the engine, then this type of experimentation may be worth your while.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #3 of 18 (permalink) Old 07-15-2006, 02:36 AM Thread Starter
Uber Member
well this is what i have figured out so far.... The mass of the cross section increases amps... meaning that if you were to cut the coil in half top to bottom, the more copper there the more amps you can push.
The more turns you get, the higher voltage you push.
so by running 2 smaller gauge wires in parallel it amounts up to moving up a gauge or 2. Question is, how many turns per pole? that is my only worry. i am sure there is some nasty formula. i may just take it it out and take the flywheel out and hook it up to a drill and mess around with the turns.
Idealy i want 12.8v at idle and 14.8 at 5.5k rpms. I think people are looking too much at voltage. yes voltage will drop as you apply load, but only if the amps arent high enough...
i think with the cooling that has been discussed earlier, a 20-40% gain in power should be a breeze with no longing effects. ::wonders if i should jump up a r/r unit to a more robust and higher wattage unit, or maybe even make my own lol::
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
post #4 of 18 (permalink) Old 07-15-2006, 04:04 AM
Once Banned
cegodsey's Avatar
Yeah, if you are gonna change the stator output, then it would be wise to change the r/r. Correct me if I'm wrong, but $110+ for a OEM r/r? Seems like a bunch of diodes and a voltage regulator couldn't possibly be that much. Really, though, you should be able to get a regulator and rectifier already made that can handle the load without costing so darn much. Then you wouldn't be stuck with the default size and shape, so you could place it about anywhere. I bet if you cooled it you'd get a bit more current from it. You ever touched one, on the outside of the bike with air flowing over it? It's gotta be better than being over the belly - but i don't know. Take yours and lay it on the sidewalk at noon, and pick it up an hour later. It's that hot.
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
post #5 of 18 (permalink) Old 07-15-2006, 07:38 PM Thread Starter
Uber Member
oh yeah
well i think the stock r/r could handle a <20% boost. but if i go over that then yes i would need a more robust r/r. if i wanted to make my own i would make sure it would be able to handle a lot more. I prob could get the parts for less then $50. all i would need is a steel box, some thermal epoxy, 3 high watt/voltage diodes, and prob set up a twin phase voltage regulator too... that way the power is always clean and the voltage control would be shared between the too(redundancy to prevent a fry). then just throw a decent size capacitor in the loop. that will make everything just about bullet proof.
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
post #6 of 18 (permalink) Old 07-17-2006, 11:10 PM
Crobins365's Avatar
I'm coming up with the same approx. value for an OEM r/r ($110 or so);and about 3x that for an OEM stator. Does anyone have suggestions for something that works but won't break the bank? I tried to pick up a NOS on eBay and apparently got outbid at the 11th hour (grrrr).
Thanks.
C
Crobins365 is offline
post #7 of 18 (permalink) Old 07-18-2006, 04:14 AM Thread Starter
Uber Member
you must have been that robins person that was bidding on it.... I am going to attempt to rewind my own. If i can get it to work, i will post. I need a donor stator though, which i will post another thread for. hopefully i can boost output to the 400-500 mark with minimal drain at idle....
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
post #8 of 18 (permalink) Old 07-18-2006, 04:41 AM
Once Banned
cegodsey's Avatar
Hey Hizzo, what is the current output of our current stator (assuming a correctly working r/r)? You said 500-550 watts, so it made me think, and I did 15amps X 70volts = 1050 watts, which means that a 15 amp fuse is probably too high for a fused stator. Needs to be more like 5 amps?
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
post #9 of 18 (permalink) Old 07-18-2006, 07:28 AM
Crobins365's Avatar
<<you must have been that robins person that was bidding on it.... I am going to attempt to rewind my own. If i can get it to work, i will post. I need a donor stator though, which i will post another thread for. hopefully i can boost output to the 400-500 mark with minimal drain at idle....>>
Ha ha, yeah, that was me. Alas. I am bidding on an '86 stator as well, but I'm still not certain that my stator is out. I'll probably win that, given that I don't need it; so if you have trouble with the do-it-yourself approach, holler - I may have a stator for you.
Seriously, though, any other options for a regulator besides just sucking it up and making the purchase? Seems like the various sites I'm looking at either offer the OEM for $110+/-, or some version of their own for more.
C
post #10 of 18 (permalink) Old 07-18-2006, 10:35 AM Thread Starter
Uber Member
well seeing that i am still a college student in EE, i may not know a whole lot yet but this i do know. the parts to make up an r/r can be had for less then $50. when i boost the output of mine, i am looking at maybe even doing my own, but we'll see. i may get tired after my stator rewind and maybe go get a 40 amp r/r unit lol...
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
