new stator....might need jb or r/r not sure - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 08-23-2011, 08:32 PM Thread Starter
Work Hard, Play Hard!!
I just replaced the stator ...since the wires were fried I also have a newer battery...my headlights went out and I did the quick fix of switching the wire and putting toggle switch in....but I have noticed that the fan isn't working...so I think the fan relay is shot as well...so thinking of replacing the junction box....could someone tell me how to test the regulator...if that is not bad then I will just replaced the junction box.....Thanks.
bierDuck is offline
post #2 of 3 (permalink) Old 08-24-2011, 10:46 AM
flitecontrol's Avatar
I believe the test is in the service manual, downloadable here: http://www.tocmanufacturing.com/File...nd%20Parts.pdf
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #3 of 3 (permalink) Old 08-24-2011, 02:48 PM
ifixf18s's Avatar
Testing the R/R is fairly easy. Start the bike, let it warm up a bit. Using a multi meter measure the votage across the battery. If its the original R/R the votage reading would be close to 12VDC. Bring up the RPMs to 3000-4000. The votage should rise to close to 14VDC. Ive read on here that the R/R could cause a stator failure and visa versa. So you may want to think about changing the R/R anyway.
When did your headlight go out? When did you do your "quick fix"? Was it before you replaced the stator? A bad stator could cause the headlight not to work. Also if you ran the new stator wires directly to the R/R the headlight would also not work. There is a yellow wire on one of the R/R connectors, at work and I dont remember which connector. This wire is spliced to one of the stator wires and it operates the headlight relay.
ifixf18s is offline
