Voltage @ coils - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 08-17-2011, 12:25 AM Thread Starter
Smile Voltage @ coils
86 VN750 A2....lost rear coil I cleaned every electrical connector/connection i could see with the seat removed. Measured 5.8 V at rear coil (wires removed) and 11.75 V at front coil. (Battery @ 12.4 V ) Appears to be a faulty Igniter Module.. Looking for a second opinion.... any help ?
post #2 of 12 (permalink) Old 08-17-2011, 05:52 AM
Crobins365's Avatar
Someone check me, but aren't there supposed to be two readings (resistance?) to check the coils? Wait until someone else weighs in, but I think there are two windings and you've got to measure them both to ascertain whether a coil's gone bad. Regardless, I have spare (used) coils and a couple of igniters (I think one's new), so if something needs to be replaced feel free to shoot me a PM.
C
Crobins365 is offline
post #3 of 12 (permalink) Old 08-17-2011, 06:23 AM Thread Starter
Smile
Rear coil (#2) measures 2.1 & 2.2 Ohms
Front Coil (#1) measured 2.1 & 2.2 Ohms
[email protected] wire connections
post #4 of 12 (permalink) Old 08-17-2011, 08:14 AM
You have a broken wire or bad splice/connection. The power to the coils comes from the battery, not the ignitor. I would suggest you do the coil mod found here in the forum.
dariv is offline
post #5 of 12 (permalink) Old 08-17-2011, 10:00 AM
Crobins365's Avatar
Found my service manual:
Primary resistance = 1.8-2.2 ohms
Secondary resistance = 19,000 - 29,000 ohms
C
post #6 of 12 (permalink) Old 08-17-2011, 04:40 PM
X2^^^^^^
Coil mod link:
https://www.vn750.com/forum/showthread.php?t=17276
post #7 of 12 (permalink) Old 08-17-2011, 05:07 PM
Just for a test. You can run a wire direct to the coil from the + side of the bat and see if the bike starts and run good.
post #8 of 12 (permalink) Old 08-17-2011, 06:06 PM Thread Starter
tried that....
NiteRider: Just for a test. You can run a wire direct to the coil from the + side of the bat and see if the bike starts and run good.
Dariv: You have a broken wire or bad splice/connection. The power to the coils comes from the battery, not the ignitor. I would suggest you do the coil mod found here in the forum.
NiteRider, Tried that, could not keep it running at idle, would not take any throttle at all.
Dariv: When measure terminal voltage @ coil terminals: (battery @ 12.4 V) Front coil: Solid 11.6 V Rear coil: 10.1 V which drops to 5.6 V within 8-10 seconds. By my Schematic rear coil receives its ground from the igniter. Checked ground to Igniter via plug...all is perfect.
Q: Seems to me the Igniter is providing a bad ground to rear coil (from within the igniter). Only front cylinder is firing, when I ran direct battery to coil, rear cylinder had some spark (appeared weak) wanted to run with starter, would not take any throttle.
u all been a great help thus far, but problem still exists...
Help !
post #9 of 12 (permalink) Old 08-17-2011, 07:40 PM
Have you tried spark plugs?
Change them around.
post #10 of 12 (permalink) Old 08-18-2011, 12:00 AM Thread Starter
LOL ...i should have thought that ! I'll try that.
Rear coil: When I measure coil 12 V lead to Chassis / battery ground......12 + V.... when measuring via 2 coil leads 9V down to 5+ V with 5-6 seconds.
