Installing New Stator - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 08-15-2011, 05:56 PM Thread Starter
Hi
I am in the process of installing a new stator and the directions obtained off of our forum have been great. I have two questions at this point (ready to put back together):
1. I ordered a new oil seal for the gear shifter lever as advised. I had to dig and wire brush the old one out of the crevice of the case and it the process I found 2 spring type washers. The question is, how do I get the rigid rubber oil seal in the crevice? If I could bend or fold it, I would be able to get it into the crevice, but it is rigid and does not bend easily.
2. I have seen 2 recommendations for installing the inside stator cover gasket, the black sticky material and the Red RTV. Is there a consensus? I belive that Lance was fairly strong about using the black.
As always, the groups input on these two issues are greatly appreciated.
Thanks
MAG659 - Mark George
Chagrin Falls, OH
1986 VN 750 - "Old Goat"
24,000 miles
Lubed Splines
MFB (Deka- AGM)
NKG - Iridiums
Plexistar II
Avon Venoms - wider
F-110/90
R-170/80
K&N Air Filters
mag659 is offline
post #2 of 3 (permalink) Old 08-15-2011, 09:11 PM
This type seal is meant to be pressed in place with an arbor and press. In the real world the old seal works pretty well when combined with a vice. I'd imagine you can gently tap it into place. A socket with a slightly smaller O.D. than the seal makes a good press tool if the old seal is damaged.
My sealant preference is Permatex Ultra Blue. A bit more expensive but it can seal on oily surfaces, doesn't stink, and is easy to work with. Its the only sealant I used to use on industrial printing presses because oil leaks suck.
sparks54 is offline
post #3 of 3 (permalink) Old 08-16-2011, 10:13 PM Thread Starter
Thanks for the feedback! The Permatex blue sounds like the way to go.
Chagrin Falls, OH
24,000 miles
Lubed Splines
MFB (Deka- AGM)
NKG - Iridiums
Plexistar II
Avon Venoms - wider
F-110/90
R-170/80
K&N Air Filters
mag659 is offline
