rear running lights question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 08-13-2011, 07:05 PM Thread Starter
Concert connoisseur
wib714's Avatar
my rear running lights are only working as turn indicators, headlight, taillight and both front turn signals and running light work fine. but the rear are only working as blinkers. I am pretty darn sure they always worked as running lights before but found this thread that says different.
https://www.vn750.com/forum/archive/i...p/t-16607.html
changed the fuse and it seemed good, am I crazy or do I have an issue, its an 86 by the way if it matters!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #2 of 5 (permalink) Old 08-13-2011, 07:44 PM
If only it had 6th gear..
DavesVulster's Avatar
On mine only the front turns are also running lights. I thought that was normal unless at some point it was changed and dual bulbs were wired in. Pop a lens and look at you bulb. Then let us know if you actually are crazy or not
DavesVulster is offline
post #3 of 5 (permalink) Old 08-13-2011, 08:06 PM
JM2001's Avatar
Fronts act as runnng lights and blinkers. Rear are blinkers only. Crazy lol
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #4 of 5 (permalink) Old 08-13-2011, 08:16 PM Thread Starter
Concert connoisseur
wib714's Avatar
holy crap I could have swore the rear always ran, you think you know a bike. I guess this might explain why the front is a 3 wire system and the rear is only a two!
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #5 of 5 (permalink) Old 08-13-2011, 08:41 PM
Ha ha! I love it. At least it's all fixed lol.
