Turn signal bulbs don't fit. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 08-08-2011, 10:44 PM Thread Starter
'03 VN750 "Rosie"
bstew7890's Avatar
My rear turn signal went out and I assumed it was the bulb so I changed it. (It was actually a wire connector that pulled apart, but that's not the point.) I decided to replace all four bulbs so I took one rear and one front to the dealer and got replacements. The new rears work fine but the fronts wont go in; I can't turn it to the right and lock it in. They look the same on the outside, including the placement of the knobs. Any suggestions?
'03 VN750 "Rosie"
Purchased in June 15, 2010
Lubed Splines
Lubed and Adjusted Clutch Cable, Throttle Cables.
Relocated Voltage Regulator
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
Legitimate Title!! (finally!) Aug 30, 2010
New AGM Interstate Battery Sept 15, 2012
2008 Hyosung GV250 (sold!)
bstew7890 is offline
post #2 of 4 (permalink) Old 08-08-2011, 10:55 PM
If only it had 6th gear..
DavesVulster's Avatar
Yeah you probably have single filament bulbs that your trying to put in front. They're 2 filament in front (1157 I think?? Been a while lol) but the pins on the two types of bulbs are different. So they wont fit in the wrong socket.
I just read your post again, by knobs you mean the pins on the bulb shaft? Aren't they offset? Maybe turn it 180 degrees. Can't imagine why they wouldn't fit if they look the same as what came outa there.
DavesVulster is offline
post #3 of 4 (permalink) Old 08-08-2011, 11:10 PM
I pulled all my signal bulbs 2 years ago to check for corrosion, clean the inside of the lens etc. I had a devil of a time turning them 90* to push back into the socket and make sure the locating/locking knobs were in the correct slot.
Are you sure you have the high and low knobs in the correct slots?
Even when the knobs are in the right slots and the bulb slides down into the socket, it can be challenging to turn them in to lock.
Walk away from it and try again in the morning after a good nights sleep. Probably slip right in.
post #4 of 4 (permalink) Old 08-08-2011, 11:14 PM
Maybe try some electrical grease on them too. Will help keep corrosion at bay also.
