Flash flood=no lights!!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 08-01-2011, 01:24 AM Thread Starter
stereopath's Avatar
Unhappy Flash flood=no lights!!!
What the heck! Flash flood in July in California! Had crazy rain while I was at church. My bike was outside exposed to heavy rain for over 10 minutes. Now I've got no lights period! Starts fine, runs fine.
Any ideas what happened? Did it short out? Will it come back after it dries?
Video I shot and edited of my 1985 Vulcan VN750
mounted iphone gps for speedo and milage
custom seat mod
stator replaced
mosfet r/r
gauges and dash removed
baffles drilled
synth oil
ear shave
de goat
412 progressive 11" shocks
Custom paint
NGK Iridium Spark Plugs
cam chain tightened
Coming soon:
spline lube
whitewall tires
stereopath is offline
post #2 of 8 (permalink) Old 08-01-2011, 08:00 AM
deleted
1988 VN750[SIGPIC][/SIGPIC]
FlacoLove is offline
post #3 of 8 (permalink) Old 08-01-2011, 03:36 PM
ifixf18s's Avatar
I started having trouble with just my turn signal lights, noticed one of them had some water inside. Had to pop the cover off and clean up some mild corrosion then they staterd working properly again. But just 10 minutes in the rain you would think would not cause that.
ifixf18s is offline
post #4 of 8 (permalink) Old 08-01-2011, 03:45 PM
I don't have a suggestion for your headlight problem, but I did enjoy watching your video, in high def. Very creative.
shnickelfritz is offline
post #5 of 8 (permalink) Old 08-01-2011, 10:08 PM Thread Starter
stereopath's Avatar
Awesome!
Thanks! Glad you liked it!
custom seat mod
stator replaced
mosfet r/r
baffles drilled
synth oil
ear shave
de goat
Custom paint
cam chain tightened
Coming soon:
spline lube
whitewall tires
post #6 of 8 (permalink) Old 08-02-2011, 12:34 AM
If only it had 6th gear..
DavesVulster's Avatar
Yeah your video was the nuts. Does your headlight come on after it's running? I had a small section of wire under the seat that was bare and it killed all my lights except the headlight because it's on a different circuit. It was a 10 amp fuse that blew.
DavesVulster is offline
post #7 of 8 (permalink) Old 08-03-2011, 09:10 PM Thread Starter
stereopath's Avatar
No the headlight and tail light don't work. Blinkers do tho but blink real fast.
custom seat mod
stator replaced
mosfet r/r
baffles drilled
synth oil
ear shave
de goat
Custom paint
cam chain tightened
Coming soon:
spline lube
whitewall tires
post #8 of 8 (permalink) Old 08-03-2011, 09:49 PM
Wow. So you have no electronics other than your ignition? How about horn and tachometer. I wonder if the junction box shorted due to the rain or a main circuit in it. Something like a fusable link on a car. Just throwing things out there as I'm thinking about things....
Tags
headlight , short , tail light
