regulator/rectifier - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 07-09-2011, 10:55 AM Thread Starter
regulator/rectifier
went for a ride this morning and got stranded witha dead battery,battery is brand new and just reaired all my sator wires..with bike running I have 13.5V at all 3 stator wires going into the R/R,i have 12.5v coming out but not on the brown wire that one reads a flat 5v...im assuming this means I need a new rectifier/regulator?..if so does anyone know if there is anyplace to get one for less than $100-$120? thanks
hoggs750 is offline
post #2 of 15 (permalink) Old 07-09-2011, 11:18 AM Thread Starter
ok correction at an idle i get 5V on the brown wire but as i raise the rpm's it climbs to about 12.5v is that normal? thanks
hoggs750 is offline
post #3 of 15 (permalink) Old 07-09-2011, 11:25 AM
Patriot Guard Rider
The DEUCE's Avatar
Copied from the Vulcan Verses.
- How to check out the R/R
If you have the Kawasaki Service Manual, you will find R/R checkout on page 15-18. If you don't I will list what is there for you. Quoted from the manual as much as possible: Regulator/Rectifier Inspection Remove the left side cover. Pull out the connector. Be sure to set the hand tester to the 100 ohm range and zero the meter(Not necessary on a digital meter) Check the resistance between the regulator/rectifier terminals as follows(there is a chart and picture in the manual which I cannot reproduce right now but I will try to put it in words for you)
A1 A2 A3 All Alternator Terminals --- --- --- Connector with pins facing you and notch at bottom --- --- ---
G M B G = Ground M = Monitor B = Battery --|__|-- (Hope that came across right)
Measure B to M - should read infinity
Measure B to G - should read infinity
Measure B to A1, A2, A3 - should read infinity
Measure M to B - should read > 10K ohm Measure
M to G - should read > 10K ohm
Measure M to A1, A2, A3 - should read > 10K ohm
Measure G to B - should read between 0.4 to 2K ohm
Measure G to M - should read between 1 to 5K ohm
Measure G to A1, A2, A3 - should read 0.2 to 0.6K ohm(200 to 600 ohm)
Measure A1, A2, A3 to B - should read 0.2 to 0.6K ohm(200 to 600 ohm)
Measure A1, A2, A3 to M - should read infinity
Measure A1, A2, A3 to G - should read infinity
If there is more resistance than the specified value, the unit has an open lead and must be replaced. Much less than this resistance means the unit is shorted, and must be replaced. Hope this helps someone out there. Dan Morgan
VN750 #9300 & VROC #33453
The DEUCE is offline
post #4 of 15 (permalink) Old 07-09-2011, 11:37 AM
ifixf18s's Avatar
13V from the stator does not sound correct. Was this 13VDC? The votage from the stator would be AC. With the bike warmed up and up on the RPMS from what ive read here you should be getting 50-70 VAC. You need to recheck this if you were testing for DC voltage. If the voltage is incorrect you need to check the continuity of the stator. Reading between each of the stator leads (stator lead -stator lead) I would say you should have 1-3 OHMS. Between each of the stator leads to ground you should have an open (no continuity). If these readings are bad I would say you have a bad stator. If thats the case most on here goes with Tim Parrot for a stator repair (rewind) $85.00. I would replace the R/R as well since it is possible it contributed to the stator failing. Again most people on here says to go with a Mosfet R/R kit $124.00. I just replaced my stator and R/R. Here is a quick check that could be because of a bad stator, does your headlight work when the bike is running?
ifixf18s is offline
post #5 of 15 (permalink) Old 07-09-2011, 12:16 PM
You should get 13+ at the bat with the rpm at about 14k. Be sure to check all the grounds especiall close to the bat.
I had a problem, I took out the stator connection an soldered the the wires together problem solved.
post #6 of 15 (permalink) Old 07-09-2011, 12:49 PM Thread Starter
thanks for the info guys im off to do some testing..i will return witht he results
hoggs750 is offline
post #7 of 15 (permalink) Old 07-09-2011, 02:39 PM Thread Starter
ok at risk of sounding real dumb..lol do I un plugh the R/R and test the plug going to the regulator?
hoggs750 is offline
post #8 of 15 (permalink) Old 07-09-2011, 03:09 PM
14k rpm? I think you mean 4k. Right niterider?
post #9 of 15 (permalink) Old 07-09-2011, 03:20 PM Thread Starter
I have actually removed the R/R and have it right here infront of me..lol It seems that no matter how i test it i dont seem to be getting any readings close to the list
hoggs750 is offline
post #10 of 15 (permalink) Old 07-09-2011, 03:22 PM
I think you can.
I would try it first, but if you get low voltage or high resisitance readings on the lead to lead tests I would pull the bullet connectors apart on the yellow stator leads and retest directly at that point. Look for corrosion or burnt wires/insulation at the bullet connectors.
