wiring harness loom tubing heat specs - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 07-06-2011, 07:27 PM Thread Starter
Wareagle1970
carolesteven's Avatar
Okay, found some of this wiring harness loom tubing at Lowes. Their site didn't have the temperature specs so I called the company. The mentioned that the high temperature is 200 degrees F.
Would this be okay for wrapping the wiring harness from the stator wires to right behind the battery box?
The link to the product is
https://images.tradeservice.com/OMHP...NE00164_D7.pdf
search for 772241
Thank you in advance,
Steven
2003 VN750 de-goated
Kuryakyn ISO Grips
Kuryakyn LED Voltmeter
coastered
Slipstreamer Hellfire windshield
Shindengen Mosfet R/R
Kawasaki Engine Guard
Fire & Steel Footpegs
Need Knifemaker to make me a seat like his
Hickory, NC
carolesteven is offline
post #2 of 20 (permalink) Old 07-06-2011, 08:45 PM
search for 772241
Steven
As long as the plastic loom doesn`t touch the exhaust pipe or the goat`s belly, it should be fine.
post #3 of 20 (permalink) Old 07-06-2011, 09:03 PM Thread Starter
Wareagle1970
Thanks Gordon. Picked up some from Lowe's tonight.
Kuryakyn ISO Grips
coastered
Hickory, NC
post #4 of 20 (permalink) Old 07-06-2011, 09:50 PM
sunpa's Avatar
More important than the temp rating of the loom is the temp rating of the wire insulation. I gather from your other posts that you have rewired the stator / regulator wiring. What is the rating of the wire insulation? The current carrying capacity rating of any particular guage is primarily dependent in it's insulation temp rating (and allowable voltage drop). The same wire will have a higher current rating in "free air" than if it is bundled in or in a conduit.
Our charging system is rated at 24 A @ 14 VDC. Assuming equal current distribution among the 3 AC stator phases, that give you 8 A(RMS) per wire.
Bundling the wires in a loom will reduce the current rating of the wires unless you use a higher temp insulation for a given wire size.
Bottom line: the loom may be just fine, but may cause your wires to overheat depending on wire guage and insulation temp rating.
- Safety First
Paul
'04 VN750
'75 CB360T
'08 Concours 14
sunpa is offline
post #5 of 20 (permalink) Old 07-07-2011, 12:06 AM
I should have remembered that sunpa.
I recall now, someone saying a long time ago that tying the stator wires together on his bike, was the cause of overheating them and burning one or two of the connectors off.
post #6 of 20 (permalink) Old 07-07-2011, 08:16 AM Thread Starter
Wareagle1970
Thanks again for the input Sunpa. I need to check the insulation of the new 14 gauge wires I replaced the existing stator wires with. Will definitely individually wrap each stator wire with good electrical tape to avoid them passing heat to each other. Will most likely wrap them from the stator all the way to the R/R, just for an extra measure. Now, would I need to also rewrap the section of the wiring harness that I removed the previous wrapping with when I rewired the stator wires, or would the conduit work fine?
Kuryakyn ISO Grips
coastered
Hickory, NC
post #7 of 20 (permalink) Old 07-07-2011, 10:57 AM
Just throwing this out there..I noticed when repairing my stator wires the previous owner had actually run the stator wires through a piece of conduit..put a few slight bends in it and uzed zip ties to secure it to the frame and believe it or not it looks good (its painted black so blends in) lol
hoggs750 is offline
post #8 of 20 (permalink) Old 07-07-2011, 11:01 AM Thread Starter
Wareagle1970
Dang, I wish I would have thought of that before I removed the wiring harness insulation. I wonder, though, with just the stator wires running through the conduit, isn't it still possible they would produce enough heat to melt them together (if they were touching in the conduit that is).
Kuryakyn ISO Grips
coastered
Hickory, NC
post #9 of 20 (permalink) Old 07-07-2011, 12:33 PM
I gotta say the copper does look pretty cool.
hoggs750 is offline
post #10 of 20 (permalink) Old 07-07-2011, 01:25 PM Thread Starter
Wareagle1970
And I like the fact that it keeps the stator wires away from the wiring harness.
Kuryakyn ISO Grips
coastered
Hickory, NC
