Anyone running custom turn signals? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 06-25-2011, 01:15 PM Thread Starter
six6six's Avatar
I was looking at some 16 LED turn signals on ebay that i liked, but i noticed they mounted way different then the stock ones, has anyone used aftermarket turn signals like this?
six6six is offline
post #2 of 6 (permalink) Old 06-25-2011, 02:44 PM
give us a link so we can tell what you are looking at. I have custom turns on my bike... but if you are doing an LED conversion, be sure to change your Thermal Flasher unit to an Electronic Flasher Unit. https://www.napaonline.com/Catalog/C...325424915&An=0
post #3 of 6 (permalink) Old 06-25-2011, 11:21 PM Thread Starter
six6six's Avatar
Thanks for the tip, im looking at these:
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
six6six is offline
post #4 of 6 (permalink) Old 06-25-2011, 11:48 PM
those will work.. you just need to make an adapter plate to mount them
post #5 of 6 (permalink) Old 06-26-2011, 09:20 AM
johnm's Avatar
I didn't use after market t/s, but when I needed to relocate the rears to accommodate saddlebags I grabbed an old set of stock t/s, removed the brittle and broken stems, then fabricated a threaded stem and bracket in order to relocate to the license plate.
It's not perfect and may not be permanent, but the price was right and I kinda like how they turned out.
This may not be what you want to do, but thought I'd throw out what can be done with little money and a little ingenuity.
https://www.vn750.com/photopost/showphoto.php?photo=3409
John
1989 VN750
VROC#31798
I'm bad with names. May I just call you dumb?
johnm is offline
post #6 of 6 (permalink) Old 07-03-2011, 07:50 AM
I bought the same ones only in black. they are sweet. the front and rears i drilled and tapped the existing holes I had and threaded them in but i was goin to mount the rears directly on the brake light housing. just drill a hole.
the fronts i was going to mount a little flat plate across the big hole using the existing bolt to hold it in place. drill and mount to that. but i decided to direct mount them. they work great. I didnt replace the flasher they only blink a lttle faster than the stocks.
ltrfred is offline
