Stator wire gauge - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 33 (permalink) Old 06-14-2011, 09:55 AM Thread Starter
Wareagle1970
carolesteven's Avatar
Stator wire gauge
Anyone happen to know what gauge the yellow stator wires are?
Thanks,
Steven
2003 VN750 de-goated
Kuryakyn ISO Grips
Kuryakyn LED Voltmeter
coastered
Slipstreamer Hellfire windshield
Shindengen Mosfet R/R
Kawasaki Engine Guard
Fire & Steel Footpegs
Need Knifemaker to make me a seat like his
Hickory, NC
carolesteven is offline
post #2 of 33 (permalink) Old 06-14-2011, 10:38 PM
There isnt one
biggestjd is offline
post #3 of 33 (permalink) Old 06-14-2011, 11:57 PM
Thanks,
Steven
Since no one has given you an informed answer I went and took a look at my stator wires.
My guess before looking was that they would be 14 or 16 gauge.
They are too small to be 14 ga, but the insulation coating is very close in diameter to the 16 ga "Grote" brand primary wire I have on a 100' roll in my cabinet.
So, because IMHO 18 ga would be too light a wire for the purpose, I think the yellow stator charging wires must be 16 ga. (shrug)
Anyone know for sure?
post #4 of 33 (permalink) Old 06-15-2011, 09:44 AM Thread Starter
Wareagle1970
Originally Posted by biggestjd View Post
There isnt one
Huh?
Kuryakyn ISO Grips
coastered
Hickory, NC
post #5 of 33 (permalink) Old 06-15-2011, 11:24 AM
Thanks,
Steven
There isnt one
Huh?
I think biggestjd is confusing the use of the word "gauge", as a unit of measure instead of as an instrument.
post #6 of 33 (permalink) Old 06-15-2011, 12:39 PM
1.5mm^2, IIRC..........
dariv is offline
post #7 of 33 (permalink) Old 06-15-2011, 01:02 PM Thread Starter
Wareagle1970
Thanks Gordon.
Well, I took the bike home at lunch. It is still not charging so I need to first, learn how to measure ohms correctly using my multi-meter, then trouble shoot the r/r, then trouble shoot the stator...
Kuryakyn ISO Grips
coastered
Hickory, NC
post #8 of 33 (permalink) Old 06-15-2011, 01:04 PM
The Reanimater
jthill524's Avatar
Location: A Little Town Along I-5 in Northern California
I used 14ga when I fixed mine.
Thanks,
Steven
JaY
"Veronica"
2002 VN750 Vulcan
Rebuilt Engine
ACCTs lubed w/TOC Springs
Pick-up Coils Gapped at .018"
Splines Lubed
Deka MF AGM EXT15L Battery
NGK Iridium IX Spark Plugs
R/R Relocation Fix
New Rear Rack
Stock Seat Repadded
Ext-BackRest
jthill524 is offline
post #9 of 33 (permalink) Old 06-15-2011, 01:23 PM Thread Starter
Wareagle1970
Thanks Jay.
Kuryakyn ISO Grips
coastered
Hickory, NC
post #10 of 33 (permalink) Old 06-15-2011, 06:59 PM
ifixf18s's Avatar
Hey, Question? Do you have a meter and could you post a photo of the front if it? There all pretty much the same, being able to read VAC, VDC and OHMS some have a few other features for capacitance and reading diodes. By your post it seems that you havent used a meter at all before. So i hope i dont get to elementry for ya. There are two leads, RED being the positive one, Black being negitive or common. My meter has 3 places to put the leads. The black will go into the common, Red will go into one marked V,ohm,mA. they should be color coded as well, The other place is for reading AMPS up to 10A. The knob on the front of the meter is for setting what you want to check, VAC, VDC, ohms (greek symbol for omega is what usually is shown). Within those settings are different scales, for example if you want to read 200 VDC them make sure you dial in a setting for that mine has a 200VDC setting yours might have something a bit higher, point it you dont set it on a lower scale. Couple final things with DC voltage the polarity matters (red lead goes to positive, black lead to negitive) if its backwards you will just get a negitive reading is all. Reading VAC polarity dont matter, OHMS it really dont matter unless your into diodes and stuff. Have you started the bike and put the meter to the battery terminals for reading VDC? should get battery voltage at idle and close to 14 VDC when you raise the RPMS, This bike dont charge the battery at idle. If you dont get a rise in voltage, Then you need to check the resistance of your stator to make sure that is good Between each of the yellow leads you should have less then 2 ohms, between each of the yello leads and ground (chassis of the bike - dont read through the paint. go to the neg term of the battery if you have to and you should have no continuity to ground at all. i rambled on and you probably have a friend that showed you all ready. Plus im sure you could find instructions for your meter online. hope i didnt bore anyone. I can be long winded in typing.
ifixf18s is offline
