Blowing fuses??? Regulator replacement - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 06-11-2011, 06:30 PM Thread Starter
blair_220's Avatar
I have recently tried replacing the regulator...After hooking everything back up the 30Amp fuse blows as soon as I put one in...I searched all wires made sure to the best of my ability there is no short (Before regulator replacement never had probelms with blowing fuses).....After trying to find a short forever I un hooked the regualtor and the bike will crank and seem like it would start (Ihave gas tank off) But the fuse did not blow then...Does this mean bad regulator or what? Or was the regulator just hooked up wrong? Please help I am so sick of this thing...I need to be riding!
blair_220 is offline
post #2 of 5 (permalink) Old 06-11-2011, 08:27 PM
ifixf18s's Avatar
Is the R/R you replaced the same type as the one you removed?
I just replaced my R/R with a mosfet there is alot of post on here about that one. My old R/R is sitting on my workbench. I replaced it because my stator went bad and am not sure if it could of contributed to it. your welcome to it if you want to pay the postage. If you would want one just to see. I left a post on your other thread a few minuites ago. With the mosfet R/R the only wires that gets hooked to it are from the stator and two new wires that go to the Batt. The other 3 wires can be cut,capped and and taped up there not needed. look at your other post i have a couple questions on there. wondering if your fuse blows if ONLY the blk/y wire is hooked up.
ifixf18s is offline
post #3 of 5 (permalink) Old 06-11-2011, 08:48 PM Thread Starter
blair_220's Avatar
With just the yellow/black wire hooked the fuse does not blow. Yes connecting to the r/r
post #4 of 5 (permalink) Old 06-11-2011, 09:13 PM Thread Starter
blair_220's Avatar
SH555-12 is the regulator I have will this work?
post #5 of 5 (permalink) Old 06-11-2011, 09:13 PM Thread Starter
blair_220's Avatar
it is off of a 93 ninja zx600c
