Need Serious Help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 06-02-2011, 09:17 PM Thread Starter
Journey's Avatar
Need Serious Help
I have a serious problem. In the laaast few months i have replaced the R/R, installed a new M/F battery and just picked up the bike from havinf a new stator installed
Hadedout on memorial day for the 1st good ride in a year.
45 miles later I had to jump start the bike. Rode for 60 more miles repeated jump start
Finally towed the bike home. Checked the battery output, wiht no load about 14 volts. With a load 10 to 13 volts.
i have had the bike for 10 months and have pushed and prayed the bike more than ridden...
any suggestions please
My Enuf.
1995 Vulcan 750
New wires and plugs
Removed and cleaned carbs
re routed air line to right ear
re built transmission
New stator
New RR
New throttle cables
New clutch cable
New wiring harness
New Ignition switch
TIME to Ride
Journey is offline
post #2 of 6 (permalink) Old 06-02-2011, 10:10 PM
flitecontrol's Avatar
What brand stator and R/R were installed? Ricks/electrosport doesn't have a great record for reliability lately.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is online now
post #3 of 6 (permalink) Old 06-02-2011, 10:45 PM Thread Starter
Journey's Avatar
ill have to check the receipt. the stator was ordered from the local honda shop
the rr was bought from a salvage supplier in october
My Enuf.
1995 Vulcan 750
New wires and plugs
New stator
New RR
New throttle cables
New clutch cable
New wiring harness
New Ignition switch
TIME to Ride
Journey is offline
post #4 of 6 (permalink) Old 06-02-2011, 11:21 PM
Might want to check out this write-up on the mosfet/shindegen r/r:
http://www.scribd.com/doc/32290153/S...tifier-Install
Are you getting 14.5 volts dc at 4k RPM?
post #5 of 6 (permalink) Old 06-03-2011, 12:42 AM
On His Lady Vulcan
wkrizan's Avatar
You already found your issue right there. Just hope that you didnt fry your stator because of it. Dont ever go with a used R/R or Stator "EVER". Good luck.
Pictures of the "Ladies"
wkrizan is offline
post #6 of 6 (permalink) Old 06-03-2011, 11:10 AM
Wareagle1970
carolesteven's Avatar
Without a load you had 14 volts? The way I understand it is without a load on a full battery you should have, roughly, 12.5 volts. Under a load and between 3-4k rpm's you should have around 13.5-14.5.
Am I wrong???
2003 VN750 de-goated
Kuryakyn ISO Grips
Kuryakyn LED Voltmeter
coastered
Slipstreamer Hellfire windshield
Shindengen Mosfet R/R
Kawasaki Engine Guard
Fire & Steel Footpegs
Need Knifemaker to make me a seat like his
Hickory, NC
carolesteven is offline
