Pickup coil clearance pics - Page 3 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
post #21 of 109 (permalink) Old 11-24-2011, 04:55 AM
92' Vulcan Rider's Avatar
My bike doesn't want to start when the motor's hot. Will this Mod help this problem?
Thanks
92' Vulcan Rider is offline
post #22 of 109 (permalink) Old 11-24-2011, 01:44 PM
Thanks
Possibly but I would look at a new AGM battery first before making this mod - the battery sorted my hot-start issues out.
post #23 of 109 (permalink) Old 11-24-2011, 04:19 PM
Thanks
post #24 of 109 (permalink) Old 12-08-2011, 05:24 PM
wicker san antonio
That is a great presentation. I did the mod about 2 years ago. Wish I had your notes then.
Thanks for your efforts.
Wicker/San Antonio
wwicker:
wwicker is offline
post #25 of 109 (permalink) Old 05-19-2012, 04:35 PM
Talking Engine Coil Modification
Spectacular!!!
It was difficult, only because a screw was stuck and i went crazy trying to get that thing off. Finally got it, then could not figure out what the gap was, because nothing was specific on any of these threads. Figured that out.
The metal was tough to file down, but i got it done. Took me about 3 hours and a lot of headache...but i took her for a ride this morning...WOW.
I have increased engine power. Great. I did it because i was having problems with hot starts. Now it started in 2nd gear, hot. I was shocked.
Just a wonderful modification. Thanks
tallredbone is offline
post #26 of 109 (permalink) Old 06-07-2012, 11:11 PM
3 questions:
1) are you trying to move the coil closer to the center of the "circle"?
2) is that the sator behind the coils?
3) 1 pair of wires that come out of the case on the upper right are for the coils i assume, what about the others?
- 1998 Vulcan 750
- Black with red
- MCCT conversion
- Pick up coil mod
- Stereo with 3.5 inch speakers
- Sylvania ridiculously bright headlight
- Westco maintenance free battery
- Vance & Hines slash cut pipes
- Custom turn signal bracket
- Arrowhead universal turn signals (rear only)
- Kuryakyn longhorn offset highway pegs
- Suzuki Savage 650 rear shocks (2 inches shorter)
- Lowered front 1.5 inches
drfraser is offline
post #27 of 109 (permalink) Old 06-08-2012, 12:38 AM
Originally Posted by drfraser View Post
3 questions:
A1. Yes
A2. The coils are the stator, (as in stationary). The metal bowl shaped part that rotates around and behind the stator is the rotor. It has a small magnet fixed in the side that trigger a pulse in the ignition pickup coils when it rotates past.
A3. There are 2 sets of two wires coming from the pickup coils,
and 3 yellow stator wires carrying 50-70 volts AC to the reg/rectifier where
Alternating Current (AC) is "rectified" to Direct Current (DC), and regulated to approx 12-15 volts.
post #28 of 109 (permalink) Old 07-16-2012, 03:39 AM
okay, so im new to vn750, sorry to revive this thread
got her after many hands, so bits are worn out
1-i got snatced/snapped pickup coil (PUC) wires
2-i dont know either my pickups are modded on the magnet point
so i set my PUC to far left (original place) n check the gap....
MASSIVE, i got 1.00mm (or marked 100) blade to slip in between
my Q's
1- when y'all say .020, that thing is in MM guage rite? .020 = 20 marked blade
----since i got a guage that marked 0.05-1.00mm, i need 20's blade???
2- on my snapped PUC, there are marked 1 dot n 2 dots, are they different??
----if they are, which is top n which is bottom??
3- whats the original PUC protrusion (magnet nipple) length?
----i checked mine, .090 blade sit flush, are they grinded off?
thats all for now, thanks for ur time
meiji_mrs is offline
post #29 of 109 (permalink) Old 07-16-2012, 01:51 PM
my Q's
------0.020 = 20 thousandths of an inch
WilliamTech
post #30 of 109 (permalink) Old 07-16-2012, 05:47 PM
owch... lucky i did not start her with that gap...
tomorrow i'll find an inch guage
thanks will. so my third Q is out of zone already
how bout no 2?? i know the wires are diff colors, but whats the dots for??
