Pickup coil clearance pics - Page 11 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
post #101 of 109 (permalink) Old 06-30-2019, 04:22 PM
MSattler's Avatar
Originally Posted by abyssdncr View Post
Clearancing the pickup coils has been a commonly referred to modification that seemed to be lacking some pics, so I took a few while I was doing the job this weekend...
In expectation of dribbling oil when the cover cam off, I put a piece of foil around the bike to prevent leaks onto undesired places. (VERY little oil actually leaked out...)
Next is to remove the three screws holding the cover on. On my bike, these screws were tight (!) and I used a phillips bit in a 1/4 drive socket to break them free. The cover was also a bit glued in place and I had to rap the cover with the handle of a screwdriver repeatedly to break it free and wiggle it off. Here is the cover showing the three screws, the cover, and their respective oring seals:
With the cover removed, you can now access the two pickup coils held on by two phillips screws each:
Instead of knocking off the inner most nub that locates the pickup coil, I decided to clearance the coil bracket hole and inner most edge with a burr bit in my cordless dremel to allow a tighter clearance. In this pic, the upper coil had been modified, but the lower hasn't:
Here's a diagram of modifications made to the coil bracket courtesy of my drarwing skills and MS Paint. The upper hole represents the modification, and the lower hole is unmodified:
This is a close-up shot of the modified bracket. Notice the little space between the bracket and outer locating nub:
I set both coils to 0.020" as described in the text write-up and the difference was certainly worth the effort.
Reassembly is opposite of removal. Hopes this helps visualize everything. Total time involved was less than an hour...
Cheers,
So where exactly do you set the .020” or .018” gap at? The bottom one is out in the middle of nowhere. I modified the top and bottom of the tops screw holes, and I have the feeler gauge, but the most basic question of what am I supposed to gap is left lingering
'08 Road King Classic
'86 VN750:
Ear Shave, K&N Filters, Mean Streak Seat, AGM battery, Blue Wire Mod, Pick-up Coil Mod, Timing Advance Mod, NGK Iridium Plugs and Wire, LEDs, Bed Liner Paint Job, Over-sized Tires, New Brakes, New Fork Seals, Progressive Springs, Kick Stand Mod, Highway Pegs, 40/140 No Shims, Vance & Hines Exhaust, New Grips, Extra Wide Emgo Handle Bars
John 8:44, REV 2:9, REV 3:9 - If you were kicked out of 109 bars, would you think the problem was you, or the 109 bars?
MSattler is online now
post #102 of 109 (permalink) Old 06-30-2019, 05:09 PM
The gap between the magnet on the rotor and the face of the pickup coil.
post #103 of 109 (permalink) Old 06-30-2019, 05:27 PM
MSattler's Avatar
And you modify all four holes? The drawing I thought referenced what the plug looked like before and after. Is this where I set the .018 or .020 gap at? Because that bottom one was huge, like 1/4”.
'86 VN750:
post #104 of 109 (permalink) Old 06-30-2019, 05:29 PM
That's it. 1/4" is awfully wide.
post #105 of 109 (permalink) Old 06-30-2019, 05:55 PM
MSattler's Avatar
Widen all four holes?
'86 VN750:
post #106 of 109 (permalink) Old 06-30-2019, 06:18 PM
It looks like some people have been doing two, but four should make them sit equal distance to the rotor. Not sure I haven't done this mod.
post #107 of 109 (permalink) Old 06-30-2019, 06:20 PM
MSattler's Avatar
Either I am retarded, or most of these steps leave a bit to imagination. The bottom one is much farther away, so it doesn’t make sense to me.
'86 VN750:
post #108 of 109 (permalink) Old 06-30-2019, 07:26 PM
Originally Posted by kc2dgq View Post
the photo in the post above is labeled incorrectly....the rotor magnet is towards the center.
Rotate the rotor untill you see the magnet come close to the pickup....set the gap closer than it was by moving the plate towards the center.
you grind both ends of the plate and elongate both holes to move the plate evenly towards the center.
Found this, post #66 in this thread.
post #109 of 109 (permalink) Old 07-01-2019, 07:48 AM
MSattler's Avatar
Thank you! I’ll finish this tonight. It still seems like the bottom one is further away
'86 VN750:
