Pickup coil clearance pics - Page 10 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
post #91 of 100 (permalink) Old 06-21-2015, 10:53 PM
coil mod
I have followed the thread, I removed my 3 screws from the cover, but cant get the cover plate off..........dont want to break it, anyone know a good way, I tried tapping it with a rubber mallet but no help. Should I pry it with a flat screwdriver?.........I dont think its ever been removed.......
RangerRick is offline
post #92 of 100 (permalink) Old 06-21-2015, 11:09 PM
Crowley
crowley1027's Avatar
Keep whacking it. (lol).
Be easy with a screwdriver. It has an o-ring. Someone may have put gasket material on it.
Let me see if i can explain this well:
-while looking directly at the plate, try to put a flathead on the left or bottom side, and try to use the frame as a pivot point. Try to apply pressure to the side of the plate while hitting it around the perimeter with the mallet.
Be patient. It will come off.
crowley1027 is offline
post #93 of 100 (permalink) Old 06-22-2015, 08:57 AM
yea, mine was like that. stuck. mine had never been removed, and the o-ring was stuck to both the cover and the case, a little prying and it popped right off
michiganteddybear is offline
post #94 of 100 (permalink) Old 07-20-2017, 10:41 PM
Sloshig's Avatar
Thanks for the post. I hope to make time for this project soon. Are these pics available elsewhere? I can't seem to assess any of them.
Sloshig is offline
post #95 of 100 (permalink) Old 07-20-2017, 11:27 PM
photobucket killed the radio store
post #96 of 100 (permalink) Old 07-25-2017, 05:53 AM
1985 VN-700
L2fish's Avatar
Well I spose I should try this mod. My 85 is acting like a jerk. Did the blowback thing, new AGM battery. She start right up cold, runs great until the temp needle gets halfway or over. Wont start easy at these temps, misfires mid throttle or hiccup as I call it. Fan comes on and I am wondering if it steals voltage away from the ignition as it is pretty freakin old. But it not on when I try to restart so nix that assumption.
L2fish is offline
post #97 of 100 (permalink) Old 07-30-2017, 11:22 PM Thread Starter
abyssdncr's Avatar
Damned photobucket... I think I got the links on page one updated. Let me know if they're working for all y'alls!
'98 VN750, Mustang Seat, F&S Engine Guards, Highway pegs, Pro-Tac backrest, Harley 58121-85B windshield lowers, Autometer 3391 voltmeter, ACCT to MCCT, pickup coils at 0.020", Coasters, National Cycle N2220, Vista Cruise Universal, Single Filter Ear Shave, Givi Monokey Sidebag Mounts, Givi E21 side bags, Knifemaker style turn signal relocation, helmet locks relocated.
abyssdncr is offline
post #98 of 100 (permalink) Old 07-31-2017, 09:25 PM
Sloshig's Avatar
Well done. You're a good fellow. Thank you.
Sloshig is offline
post #99 of 100 (permalink) Old 03-17-2018, 09:13 PM
ubertalldude's Avatar
just performed this mod after reading about this years ago. used a dremel to modify the bracket and got shavings all over the place, total PITA when they stuck to the pickups. microfiber cloths are your friend!
finally got it modified properly so I could set it snug to .020", cleaning the Oring and gasket, then refitting everything and doing a test start it seemed to start more easily and was definitely a little happier to rev considering how it was cold no choke. we'll see after I test ride it but so far it seems successful. thanks again, OP
ubertalldude is online now
post #100 of 100 (permalink) Old 07-31-2018, 04:17 PM
Edy
Any chances to re-upload the pictures? Not showing again
Edy is offline
