Voltmeter showing close to 16v @ 4000rpm - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 05-21-2011, 05:00 PM Thread Starter
Hi to all,
I recently connected a voltmeter to my bike which has a Yuasa Maintenance Free battery. Its showing round 12.3 volts with ignition on, round 14 volts at idle and goes up to round 15.6 volts at around 4000 rpm. Is this normal or does this smell like trouble?
Cheers, Alan
malteser66 is offline
post #2 of 8 (permalink) Old 05-21-2011, 07:36 PM
Calif Rider
weh44att's Avatar
Did you check the voltage at the battery in this test ? It really should not be that high at 4000 RPM. Clean up your connentions on the yellow wires coming from the stater and then the connection to the RR and then see what it reads. The RR maybe trying to over charge the battery, they do this when they start to go out.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #3 of 8 (permalink) Old 05-21-2011, 08:38 PM Thread Starter
Hi WEH44ATT,
Lately I had the stator cover removed and a new sealant gasket was applied by my mechanic as it was dripping oil. Could it be that during this fix something was misplaced? Which connections and yellow wires are you talking about, could you please specify..... also note that I removed all the wire plugs connections to the R/R and soldered all the wires appropriately and used shrinking pipes etc.
Thanks, AL
post #4 of 8 (permalink) Old 05-21-2011, 08:42 PM Thread Starter
yes voltage mentioned is from battery...
post #5 of 8 (permalink) Old 05-21-2011, 08:56 PM
Originally Posted by malteser66 View Post
Hi WEH44ATT,
Thanks, AL
Sounds like you already soldered and shrink wrapped the wires where the "bullet" connectors were used on the three yellow wires from the stator to the r/r.
Disconnect the 6 pin connector from the r/r and clean contacts with plastic safe electronic contact spray cleaner. Seal with dielectric grease when you reassemble.
post #6 of 8 (permalink) Old 05-21-2011, 09:09 PM Thread Starter
Yes I did remove all the bullet plugs, also my R/R has no 6 pin connector as its an aftermarket R/R, I think its an electrex model, its bigger than OEM and the wires go directly into it without any connector. Could it be from the stator side or its just coincidence that maybe the R/R is showing the first signs of failure just after the mentioned fix. I`m pretty stressed about this as I had booked a one week bike trip in Sicily coming month and for sure I don`t want to be left stranded on the road there..... hmmmm
post #7 of 8 (permalink) Old 05-21-2011, 11:52 PM
Calif Rider
weh44att's Avatar
Soory I did not get back to you Maltesler, had to go to a little kids baseball game. As OHass said looks like you have all leads soldered and sealed. See if you can check the voltage coming out of the RR as the bike is running.The RR regulates the amount of voltage that goes to the battery, seems that it is trying to over charge the battery. I had something about the same thing happening but mine was a bad soldered connection and the regulator was trying to compensate.
2004 25,500 miles
Headlight modulator
R+R relocation
Fused Stator
Ride-on in tires
iridium plugs
weh44att is offline
post #8 of 8 (permalink) Old 05-22-2011, 03:17 AM Thread Starter
Not to worry, I have to check deeper into this...and get back to you guys, maybe I should drive the bike a bit more and re-check the values ....I have just finished from my 12hr night shift and rode back home in rain bike is all muddy now, needs a good wash and I need some good sleep.
Cheers, Al
