Failed fuel guage - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 17 (permalink) Old 05-14-2011, 02:27 PM Thread Starter
Failed fuel guage
When I started the bike up earlier this year, early April, everything was fine. A couple of weeks ago I started ir for a potential buyer, and the fuel gauge was not working. When the key is turned on, the gauge lights up, and the needle actually goes down from it's off position. I know the tank is over 3/4 full. Is this a failed sending unit? Or an electrical short or break?
If it wasn't for time, everything would happen at once!!
Flap1 is offline
post #2 of 17 (permalink) Old 05-14-2011, 04:33 PM
Bronson's Avatar
Hi: I can't think of a reason why the guage would go lower than E unless the polarity were reversed somehow. Any way, check the wiring first for continuity. If no faults are found then the sending unit is most probable cause. It could be mechanically stuck down, which seems unlikely, or an electrical fault. The resistance should change in relation to float position, which you can test if you remove the sending unit, with a multimeter.
If still no fault found, then the guage itself may be the culpret.
Hope others have input or experience with this. I will follow the thread to learn from your findings.
Bronson
2005 VN 750
Plexistar windshield
.040 pilot jets.
Splines lubed 1955 mi.
Iridium plugs
Reset pickup coil gaps.
Metzeler ME=880s
Shindengen MOSFET RR
V & H Cruzers
Degoated
Speed bleeders
MCCTs.
Bronson is offline
post #3 of 17 (permalink) Old 05-15-2011, 12:53 PM
Chucklehead
dragon159's Avatar
Seems to be a common problem, mine wasn't working when I got it. It ended up being a broken connection in the sending unit in the tank. I was able to solder it back together after a few hours of monkeying. I suggest pulling the sending unit and checking resistance across the sweep of the float, and then you might have to test your patience opening it up and finding the break, it can be done, mine is still working .... for now.
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #4 of 17 (permalink) Old 05-28-2011, 12:23 PM Thread Starter
The part that confuses me it that the needle moves to below "E" when the key is turned on. That seems like it is getting a signal from somewhere, so I am tending to doubt the bad fuse/broken connection theory. But, I'm by far no expert. Is there a simple way to check for a stuck float? And to free it?
Flap1 is offline
post #5 of 17 (permalink) Old 05-28-2011, 12:42 PM
Chucklehead
dragon159's Avatar
The easiest way to check for stuck float (but not the neatest) is to pull it from the tank and physically check it. At that point you could reconnect it to the bike and move the arm and see if the needle moves.
2 into 1 exhaust
Spitfire windscreen
Plutonium plugs
More to come
post #6 of 17 (permalink) Old 05-28-2011, 01:49 PM
Can you see inside the tank with a flashlight, then reach in with a piece of wire to move the float lever?
post #7 of 17 (permalink) Old 05-28-2011, 04:12 PM
Chucklehead
dragon159's Avatar
There I go overthinking again ... too eager to grab wrenches .....
2 into 1 exhaust
Spitfire windscreen
Plutonium plugs
More to come
post #8 of 17 (permalink) Old 05-28-2011, 06:07 PM
bigbluezuk's Avatar
Mine had a broken connection like dragon was describing. There is an "L-like" piece in there that broke right at the bend. I too was able to solder it back after an hour so of rigging. I think I actually wound up drilling a hole in the base, screwing in a small screw and soldering to that. I could not get solder to stick to the brass/copper parts.
1995 VN750 - 10K
bigbluezuk is offline
post #9 of 17 (permalink) Old 05-28-2011, 11:29 PM
My guage did not function when I bought the bike..... a few months later I replaced the sending unit which enabled the guage to function. My sending unit had a broken coil wire on the action side, which I figured would not function 100% normally after soldering. Good Luck
post #10 of 17 (permalink) Old 05-29-2011, 01:11 AM
Patriot Guard Rider
The DEUCE's Avatar
See Page "15-46 Electrical System" of the Kawa Service Manual and it explains how to test your fuel gauge by removing your seat, locating the fuel gauge connector and jumping it with a small gauge wire. Very simple and it will tell you whether your gauge is bad or your float.
VN750 #9300 & VROC #33453
The DEUCE is offline
