Electrical problems - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 05-12-2011, 11:12 PM Thread Starter
blair_220's Avatar
Electrical problems
While riding my vulcan a few days ago the tachometer, headlight, running rear light and horn all quit working. The turn signals will still work and the bike will still start and run..... What would cause all of these to stop working at the same time? or is it just a coincidence that they all quit at the same time?
blair_220 is offline
post #2 of 7 (permalink) Old 05-12-2011, 11:29 PM
check the headlight fuse
post #3 of 7 (permalink) Old 05-17-2011, 07:25 PM Thread Starter
blair_220's Avatar
I have checked all fuses... Sorry should have put that in the first post... They were all good
post #4 of 7 (permalink) Old 05-17-2011, 07:37 PM
I have a problem ... When turning handlebars right, my Hi-Beam Headlight goes out... I switch to Low-Beam immediately. I believe both our problems may be in the wiring harness near the handlebars.
post #5 of 7 (permalink) Old 05-17-2011, 10:08 PM
Blair, do the lights on the dash work? I had a similar problem, turned out to be a loose solder point in the ignition
km60155 is offline
post #6 of 7 (permalink) Old 05-17-2011, 11:22 PM
Into the Darkness
NetMatrix's Avatar
Check your solder points in the location mentioned, and also check all of your connections, and make sure there is no corrosion in them. I had a bit of a problem like that on my gator and come to find out there was some corrosion in the connector plug. The only thing I lost in my ordeal was the headlights, but it is a good idea to check for that problem. There is a spray can that eliminates the corrosion at your local auto parts store.
English Version
ACCT to MCCT conversion video
https://www.vn750.com/forum/showthread.php?t=18235
ACCT to MCCT Conversion Thread created by wib714
https://www.vn750.com/forum/showthread.php?t=17917
Proximity Construction
NetMatrix is offline
post #7 of 7 (permalink) Old 05-18-2011, 07:33 PM Thread Starter
blair_220's Avatar
The turn signal dash lights work when on but no neutral switch or tac lights or any of that. I will try and check into that thanks
