1988 vn750 ignition problems please help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 05-05-2011, 05:30 AM Thread Starter
keep it trashy
Unhappy 1988 vn750 ignition problems please help
First let me start by saying this is my first vulcan ,found it in a Harley owners garage it came with a clean title and 33k miles on it ,i am now the owner and only paid. 350$ ....the problem.the bike gets spark if one coil is hooked up.but if i hook both coils up there's nothing to either coil . I've tested both coils and they both work. Pickup coils work because if they were bad i wouldn't get any spark at all....right? The only other thing is.....the cdi box....which new is more than what i paid for the bike.and if i buy one does it matter what year? Or is it okay as long as its a vn750 cdi box? This is driving me crazy. please help....does anyone know what's wrong???? And does anyone here have a used one i can buy?i love to ride and just want to be back with my knees to the breeze. Thank you guys
rat-life87 is offline
post #2 of 12 (permalink) Old 05-05-2011, 07:40 AM
deleted
1988 VN750[SIGPIC][/SIGPIC]
FlacoLove is offline
post #3 of 12 (permalink) Old 05-05-2011, 09:39 AM
Member? ... check.
ZCraggRatt's Avatar
Do get a maintenence free batt.
Make sure and check/clean the engine and frame ground points to batt(-).
Do buy the iridium plugs.
Check/replace any ignition wiring that shows cracking or deformity.
Good hunting ...
~~C8> Ratt
________________________
'91 VN750 - Cosmic Splendor/Candy Wine
Done: Coastered, .020 ign., Iridiums, VM
Plexistar II, MCCT's, Relocated MOSFET
Next: LED's
Will Do: Horns, Shave(maybe)
ZCraggRatt is offline
post #4 of 12 (permalink) Old 05-05-2011, 08:35 PM Thread Starter
keep it trashy
Thanks guys,no bad wires.battery is full 12 volt.i usually keep my trickle 1.5 on it.got the plugs and cleaned up all my ground wires, same issue.again if both coils are connected neither one gets spark but if i disconnect one the other throws awesome blue spark....vise versa.
post #5 of 12 (permalink) Old 05-05-2011, 09:34 PM
Calif Rider
weh44att's Avatar
Did you do some work on the bike before this happened. Did you mess with the wires going to the coils or other electrical wires for the ignition. You could have a wire or wires crossed and when it is all hooked up the hot wire is being grounded. I see after reading the whole thread you bought it this way. The original PO may have messed with some wires and got them backwards. This is what it seems to have happened. Just another thought to try and help.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #6 of 12 (permalink) Old 05-06-2011, 01:17 PM
Member? ... check.
ZCraggRatt's Avatar
rat,
I would definately go through the IC Ignitor resistance checks as outlined in the downloadable maintenence manual sheet 15-24. If there was a problem with the IC Ignitor, it may show up. If the ignitor checks out good, then trace and verify/inspect wiring as shown on sheet 15-19 of the same manual. Checking the coils with an ohm meter is a good check, but one of them may be behaving differently under high voltage.
Unfortunately, this problem may not be experienced by many before, making it more difficult to arm-chair diagnose.
Good hunting ...
~~C8> Ratt
Next: LED's
post #7 of 12 (permalink) Old 05-06-2011, 01:48 PM
humm.....never heard of this problem before. I guess I would "ring out" the wires from the coils to the CDI first. you really need the schematic to check out the ign. circuit...
dariv is offline
post #8 of 12 (permalink) Old 05-06-2011, 02:41 PM
Member? ... check.
ZCraggRatt's Avatar
You can find ignitors on ebay for just over $100 (buy it now).
As far as i can tell, any VN750 model year should work.
post #9 of 12 (permalink) Old 05-06-2011, 05:06 PM
or you could check this thread: https://www.vn750.com/forum/showthread.php?t=18023
dariv is offline
post #10 of 12 (permalink) Old 05-08-2011, 10:57 PM Thread Starter
keep it trashy
Do you still have the Cdi box for sale and if so how do i go about buying it?
Tags
cdi box , ignition , spark
