Speed/ODO Malfunction - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 05-03-2011, 04:51 AM Thread Starter
Captive New Yorker....
peterherrm's Avatar
The speedometer and odometer on my '94 750 are not functioning at all. Could this be electrical?? The tach seems to be functioning properly, but neither it, or the Speedometer light up. Any help would be greatly appreciated. Pete
peterherrm is offline
post #2 of 8 (permalink) Old 05-03-2011, 09:15 AM
scuba's Avatar
check the cables. If that's not the problem, unbolt the two bolts on the side of the cluster and take it off and check the wiring. It's very basic wiring. Could be a lose wire or something. As far as the light up problem that's probably just a bulb. I have a 94 vulcan 750 and had to replace the speed/tach because it was malfunctioning. So I bought two extra sets off of ebay.
www.vulcanriders.us scuba
vn750.com scuba
vulcanforum.com scuba54220
vroc.org VROC # 32658 (scuba)
1984 kz750 ltd
1982 yamaha maxim 750
2002 nomad trike
1978 suzuki 250
1964 harley amf
1987 yamaha venture 1300
1984 honda silverwing
custom exhaust
custom mirrors
custom grips
custom floorboards
ride-on tire sealant
corbin seat and backrest
custom exhaust
willie & max saddle bags
scuba is offline
post #3 of 8 (permalink) Old 05-03-2011, 10:03 AM
Take the cable out from where it attaches to the mechanism on the front wheel. you could spin the wire inside the cable or see if it's broken.
post #4 of 8 (permalink) Old 05-07-2011, 10:57 AM Thread Starter
peterherrm's Avatar
The cable was broken, thank you for the responses...... Do I need to lube any ends of the new cable before I install??? Thanks.
Pete Herrmann
Bought 4/2011 28k Miles,
New Rick's Motorsports R/R
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
post #5 of 8 (permalink) Old 05-07-2011, 12:20 PM
JM2001's Avatar
[QUOTE=peterherrm;172819]The cable was broken, thank you for the responses...... Do I need to lube any ends of the new cable before I install??? Thanks.[/QUOT
Yes, I use white lithium grease, tube not spray can. It will help stop your cable from breaking again.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #6 of 8 (permalink) Old 05-07-2011, 12:24 PM Thread Starter
peterherrm's Avatar
Ironically, I just walked out of home depot with a tube of white lithium grease.... Thanks for th quick reply!!
Pete Herrmann
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
post #7 of 8 (permalink) Old 05-07-2011, 01:43 PM
Ceal's Avatar
Might want to open up the speedo and clean it. Mine had the same problem, the cable was broken... I put on the cable and took the bike out. It worked fine for like 3 minutes then it started making a weird noise and now the speedo doesn't work. I bet it was dirty inside from not being used for a long time and this made it fail.
Just something you might wanna check before running it.
Ceal is offline
post #8 of 8 (permalink) Old 05-08-2011, 08:16 AM Thread Starter
peterherrm's Avatar
I opened up the Speed-O, blew it out a little, put the new cable on, and it works perfect now. Thanks for your help!! I went on my first ride by myself yesterday, did 150 miles, I'm hooked!!
Pete Herrmann
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
