where should i get a R/R? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 05-02-2011, 06:36 PM Thread Starter
ifixf18s's Avatar
I just replaced my stator since the original one burned up and had open legs. I want to replace my R/R as well. i heard that it could of contributed to the stator failing. Where can i get one and what kind? Im sure a KAW part will cost me both arms and legs. I dont do ebay. I heard a mosfet one is the way to go.
ifixf18s is offline
post #2 of 11 (permalink) Old 05-02-2011, 07:16 PM
dariv is offline
post #3 of 11 (permalink) Old 05-02-2011, 08:06 PM
I just rec'd my mosfett last week after re-doing my stator also. I installed it over the weekend and the readings showed 14v+ almost immediately at idle. I rec'd everything in the kit setup that his website showed. Between the website and instructions it was pretty easy. I did have to lengthen my 3 yellow stator wires because I have my R/R relocated but that only took and extra 10 mins. FYI for ya if you go this route. The other 3 wires from the stock R/R plug get taped up and tucked away.
IndyVN is offline
post #4 of 11 (permalink) Old 05-02-2011, 08:51 PM
bigbluezuk's Avatar
+1 for Shindegen. Let us know if you have trouble getting it going. Its pretty easy.
1995 VN750 - 10K
bigbluezuk is offline
post #5 of 11 (permalink) Old 05-02-2011, 09:26 PM
Chuck A.'s Avatar
Got a MOSFET a few months back. Well worth the money. Get the kit, has all the connectors you need.
Chuck A. is offline
post #6 of 11 (permalink) Old 05-02-2011, 09:45 PM
I've got a used one for sale. Let me know if you're interested.
km60155 is offline
post #7 of 11 (permalink) Old 05-02-2011, 10:21 PM
I am with all these guys this could be the single most important upgrade yet for the VN70's trouble plagued charging system,and should result in lower heat in the stator which= longer life and more reliability.
post #8 of 11 (permalink) Old 05-02-2011, 11:15 PM
Link to installation instructions for mosfet/shindegen r/r on a vn750:
http://www.scribd.com/doc/32290153/S...tifier-Install
post #9 of 11 (permalink) Old 05-03-2011, 09:50 PM Thread Starter
ifixf18s's Avatar
r/r hook up question
Ok im looking at the mosfet R/R and it has 2 connectors, one is for the stator wires, simple. The other connector also has two wires one for the + term for the batt and one for the - term. I understand that these two wires will come in the kit and i dont use the bikes original wires. BUT what do i do with the brown wire that goes to my loads ie lights, horn etc..
ifixf18s is offline
post #10 of 11 (permalink) Old 05-04-2011, 10:23 PM
"where should i get a R/R?"
From a pirate?
(and it's an R/R, not a R/R) Arrrr.........
