Tach drops to 0 bike dies - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 04-30-2011, 08:08 PM Thread Starter
Just picked up a 1995 750 vulcan, went out for a ride and when crusin at 65 the tack dropped to 0 rpm and engine died.
Pulled over to the side of the road, waited a few minuets and re-started bike no problem, but it did the same thing after just getting rolling again.
Re-started again after pulling off the road and drove straight home without another incident.
I can't recall if I put the kickstand down each time I stopped, but was thinking maybe (hopefully) this is caused by the safety switch for the Kickstand.
It's like the ignition just died.
What do you all think?
immjg is offline
post #2 of 11 (permalink) Old 04-30-2011, 08:26 PM
Git-R-Done!
AZ Kev's Avatar
It could be that, though it seems weird it would have happened while cruising down the highway, esp. the way it works. I will be curious to see what others post - hopefully not the stator, as it sounds like that can be a bit of a bugger.
Good luck : )
AZ Kev
Arizona Kev
1989 VN750
7800 orig mi when purchased Jan 2011
Turned 11,000 mi Nov 2011
Saddlebags
Taillight relocation kit
Chad's highway peg mounts
Emgo Pegs
Aftermarket mirrors
Dunlop D404's
Otherwise, all stock
"But it's a dry heat - like the inside of an oven"
AZ Kev is offline
post #3 of 11 (permalink) Old 04-30-2011, 08:44 PM
It doesn`t act like a sidestand switch.
The intermittent nature of the problem sounds more like a bad connection in the ignition switch.
post #4 of 11 (permalink) Old 05-01-2011, 12:00 AM
clock152's Avatar
check your R/R... sounds like your getting a bad charge on the battery... also check out/search POGS...this might be the case as well.
clock152 is offline
post #5 of 11 (permalink) Old 05-01-2011, 01:27 AM Thread Starter
I will check into this. I believe this could be possible since the volt meter attached to the system still looked ok. This would lead me to think it is not a bad battery or R/R. I don't suspect POGS, didn't sputter, there was no indication in advance of the Tach dropping to 0.
So I like the ignition switch suggestion, will look into that.
Thanks
Malcolm
immjg is offline
post #6 of 11 (permalink) Old 05-01-2011, 01:30 AM
Journey's Avatar
sounds ike the ignition switch mine did the same thing till i fixed it
My Enuf.
1995 Vulcan 750
New wires and plugs
Removed and cleaned carbs
re routed air line to right ear
re built transmission
New stator
New RR
New throttle cables
New clutch cable
New wiring harness
New Ignition switch
TIME to Ride
Journey is offline
post #7 of 11 (permalink) Old 05-01-2011, 02:54 AM
Ignition switch is the most likely culprit; I've had it happen exactly like that, two different switches.
The POG (Plastic Oil Gear) problem was with '98 Classic (1500 E1) and the '99-up 1500s. Earlier models, from '96-99 D and L (C) models, and '87-'99 A and B models, had the POG, but I know of only one failure in an A model. Nobody's ever figured out why later ones failed, and earlier ones didn't.
The POG is not a problem with the VN750; it ain't got one. The oil pump is chain driven off the balancer shaft, not direct gear driven.
J.D.
Kerrville, TX
'95 Vulcan 750 "Therapy II",
aka "Raggedy Ann"
'95 VN750 project
'03 VN800B "The Little Black"
'04 VN800E Drifter project
'93 VN1500A custom project
VROC #16185
GCVROC #33
J.D. is offline
post #8 of 11 (permalink) Old 05-01-2011, 12:46 PM
JD, they are talking about the (Phantum Out of Gas.)
post #9 of 11 (permalink) Old 05-01-2011, 02:06 PM
Are you saying the tach dropped to 0 ..then the bike died...or that the tach dropped to 0 when the bike died...( a "Duh" for sure there.. ) ???
Cause if the tach dropped first... it has to be an electrical issue..
post #10 of 11 (permalink) Old 05-01-2011, 06:02 PM
Ah; thanks James; my mistake. I wasn't even thinking about that. Even that wouldn't apply here, tho; the "phantom out of gas" phenomena usually doesn't cause the bike to suddenly die and the tach suddenly drop to zero. It just acts like it's running out of gas. The ignition switch losing contact almost always does.
Jim
J.D.
Kerrville, TX
aka "Raggedy Ann"
'95 VN750 project
VROC #16185
GCVROC #33
J.D. is offline
Tags
died , ignition , kickstand , switch
